Originally posted by pres589 I'd like to see a scene where creating underexposed areas in a frame works well with newer glass and doesn't work well with older glass. This doesn't make sense to me. What it sounds like is improper metering for the scene creating images that are hard to pull together in post.
I agree. In fact, I would like to see actual proof that this works with newer glass. The practice of intentional underexposure and pulling shadows depends a great deal on the software used for RAW conversion and really does not work well at all with JPEGs.
I have done some experimentation with this using files created specifically to test what happens with a shadow pull by sampling the RAW file directly for the actual value distributions (there are only eight tones recorded for the bottom three EV at capture) and comparing those data with what results from both a one EV global pull and one EV shadow pull in Lightroom. The result are not what one might expect. The tool apparently inserts tones based on best guess of what should be there.
