11-10-2008, 12:10 PM   #1
Lens Compatibility: M + A Series on K200D
Hey all. Just a question, as stated above. I might get the opportunity to pick up a whole bunch of Pentax M and A series lenses on the cheap. I wanted to know if they will work with the K200D. I know the Auto-Takumar lenses won't fire except wide open, and was wondering if I can expect similar issues with the bayonet-mount M and A series.
Thanks.
11-10-2008, 12:15 PM   #2
forensicscientist's Avatar
they work...
They will work just fine......
11-10-2008, 12:19 PM   #3
A is good, but Centerweight Metering
for M, see the link in this article, Stop-Down Metering
https://www.pentaxforums.com/forums/pentax-photography-knowledge-base/39308-m...al-bodies.html
11-10-2008, 12:59 PM   #4
gokenin's Avatar
QuoteOriginally posted by drewdlephone Quote
Thanks.
as far as the takumar lens if you are using it on the K200 you have to make sure that the switch on the side that changes the lens from auto to manual is set on manual then you will be able to change the aperture and the lens will no longer be shooting wide open
11-10-2008, 03:39 PM   #5
Transit's Avatar
Thanks.
Mine fire at all apertures
k-mount, k200d, lenses, pentax lens, series, slr lens
AF-240 / AF-330 SB compatibility with K200d jedcrocker Pentax Camera and Field Accessories 1 12-27-2009 06:32 AM
Old lens compatibility Lane Pentax SLR Lens Discussion 15 04-03-2009 10:36 PM
K200D Battery compatibility ShutterLag Troubleshooting and Beginner Help 10 03-04-2009 03:03 AM
Vivitar RL 2650 Flash compatibility with K200d mrpackerguy Flashes, Lighting, and Studio 2 08-18-2008 09:29 AM
DA-series vs A-series lens .. does it make a diference on a dSLR? dresden_phoenix Pentax DSLR Discussion 16 05-03-2008 03:56 PM
All times are GMT -7. The time now is 02:13 PM. | See also: NikonForums.com, part of our network of photo forums!
