11-10-2008, 08:00 PM   #1
Converter Issue
Hi All
I have just been loaned a TAMRON Pz-AF MC7 2X Tele-converter.
Here's the problem..............
When I put it on my DA 18-55, it works great at 18mm. It focuses slowly (jumps around) but I DO get focus lock. When I zoom out to 55mm, it will NOT focus, even on manual.
When I put it on my DA 50-200, same thing. Great at the low end, but won't work at the high end.
It focuses at 50mm on the 50-200, but NOT at 50mm on the 18-55????
Throw it on the Sigma 175-500............same thing! Focuses at 175, but not 500.
Again.............Focuses at 175 on the 175-500, but not at 175 on the 50-200??
I'm very confused.
The only thing I can come up with is maybe it's some kind of physical/mechanical issue? When I zoom out, maybe one of the elements gets in the way? Shifts the focal point?
I don't know.
Suggestions???
11-10-2008, 08:40 PM   #2
Wheatfield's Avatar
QuoteOriginally posted by stgmgr Quote
Hi All
I'm very confused.
I don't know.
Suggestions???
Is it possible that as you zoom out, the lens is getting dimmer to the point that the AF is out of range?
Most consumer lenses are not constant aperture, and can lose a stop or more of speed during zooming from short focal length to long.
11-11-2008, 04:39 AM   #3
palmor's Avatar
Yup that would be a problem. At the short end of those lenses even with the TC you still have enough light to focus but at the long end you don't. Don't forget you loose half your light when you use a 2xTC (a f/2.8 lens becomes a f/5.6 lens etc).
John
11-11-2008, 05:16 AM   #4
Lowell Goudge's Avatar
Something to remember when looking at either a TC or the pentax 1.7x AF TC..
the 1.7 x AF TC is only gauranteed for F2.8 or faster lenses (f4.5 when TC attached) Many including myself have posted repeatidly that it works fine with F4 lenses, (F6.7 when TC attached) BUT that is the real limit.
Pentax AF regardless of camera etc, simply won;t focus reliable below F6.7. I believe most other makers are the same.
Sure you cn get lucky in bright sunlight, but that is about it.
11-11-2008, 05:23 AM   #5
konraDarnok's Avatar
Yep. Generally it's recommended to have at least an f/2.8 lens to use a teleconverter. But in practice, it works pretty well down to f/4. At f/5.6 your getting pretty iffy performance.
A 1.5X teleconverter will loose 1 f-stop, a 1.7X teleconverter will loose 1.5 f-stops, and a 2X teleconverter will loose 2 f stops.
F-number - Wikipedia, the free encyclopedia
At 55mm on the kit lens with a 2X teleconverter, you're asking the auto focus system to operate at f/11.
It's just not going to do that.
11-18-2008, 07:03 AM   #6
Thanks all for the info.
Guess I'll have to stick to bright sunny days, or better yet, just give it back to my friend.
Thanks again.
11-18-2008, 01:52 PM   #7
Marc Sabatella's Avatar
Don't forget manual focus!
11-18-2008, 07:17 PM   #8
raider's Avatar
I have always seen there are 2 variants of 1.4x Tamron TC. One is i think MC4 and the other MC7. What are their differences? The MC7 one is more expensive and bigger though.
11-18-2008, 09:23 PM   #9
Canada_Rockies's Avatar
QuoteOriginally posted by raider Quote
The MC7 is a seven element converter, the MC4 is a four element converter. The quality is very much better with the 7 element design. That's where the higher price comes in. There are more elements to grind and match up.
11-20-2008, 01:38 AM   #10
raider's Avatar
Thanks Canada Rockies for the explanation.
50mm, da, focus, issue, k-mount, pentax lens, slr lens
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 5 06-11-2014 01:14 PM
Possible Kx Issue? UnknownVT Pentax DSLR Discussion 21 11-29-2009 06:46 PM
A printer issue, or a processing issue... FHPhotographer Digital Processing, Software, and Printing 0 10-03-2008 12:13 PM
All times are GMT -7. The time now is 06:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
