Originally posted by Kiddo70 Can a lens perform better on a small sensor than it does on a full frame sensor? For example, I have seen a review that reported that the FA 31mm performed better on a K-70 than it did on a K-1. Is the central portion of the lens used on the small sensor compared to all of the lens on the larger sensor?
The lens itself is not performing better, but as other have pointed out, the main reason it appears better on an APS-C sensor for a full frame image circle is that you are only getting the sweet center spot and none of the potential issues of resolution, vignetting, distortion, or chromatic aberration in the corners and edges.
Three other potential factors:
a) The FA lens, unlike the DFA lenses, were designed for film which allow light to strike the film from a greater angle than a digital sensor that has glass and layers of RGB pixels. These issues are exacerbated in the edges and corners on a film lens vs. a DFA or DA.
b) The 36Mp K1 is going to reveal optical flaws that a 24Mp K70 won't. I've seen this with the Nikon Df (FF 16Mp) users getting amazing results with older lenses that higher Mp FF Nikons don't.
c) Sample variation: With the lens tested and what and how it was tested by the reviewer may have skewed the results in favor of the K-70.
