Given some of the responses, it might be worth addressing the matter of size and weight.
The DA Limited primes are, by design, compact and lightweight. The DA20-40, whilst bigger, is also fairly compact for a reasonably fast zoom, and comparatively lightweight.
The DA16-85 and Sigma 17-50 f/2.8 have been mentioned, and both are excellent choices optically - but they're both significantly larger and heavier than the DA20-40 (roughly twice the weight, give or take). The DA18-135, also mentioned, is shorter than the 16-85 and a bit lighter, but still way heavier than the 20-40, and roughly equivalent to a trio of DA Limited primes.
All of the lenses above could be decent choices depending on the OP's use cases, preferences and tolerances...
