Originally posted by Serkevan While hiking or traveling I always put a filter on any walkaround lenses - much easier to clean the inevitable smut from the filter than from the front element, and far less dangerous if you're half as clumsy as I am
. Haven't really noticed any resolution loss so far...
The exceptions are the M20/4 (I've managed to photograph my fingers holding the camera - of course it's gonna vignette with anything you screw there
) and on my longer lenses I don't put filters because they tend to have deep hoods and they only come out when they are needed, so less risk.
When I first joined these forums - and for a good few years after that - I fitted UV filters to every lens I owned, for exactly the reason you mention... cleaning in the field. On particularly wet and windy days, I've been known to use a shirt cuff or handkerchief to wipe the filter free of rainwater, sea-spray and/or grime
A couple of incidents made me a lot more selective about using them, though...
The first was a similar experience to
Sandy Hancock @Paul the Sunman; where I found some of my photos had strange diagonal line artefacts in the bokeh, and in some cases the character of the bokeh changed (it was busier - less smooth - than expected). I thought it was only happening at long focal lengths, but looking back at my photos and posts, it appeared on some of my DA70 Limited shots too. I narrowed the problem down to a Kenko filter, and that led to me testing
all of my filters, discarding any that produced obvious artefacts.
For a time after that, I would leave UV filters on my lenses "just in case", but remove them prior to shooting when conditions were fine.
The second incident was an indoor shoot with my little Q7, where I subsequently found that a large number of the photos I took had nasty ghosting artefacts due to reflections from ceiling lights, exacerbated by the filter on the lens - which I'd
forgotten to remove
After that, I took the filters off almost every lens I own.
If I'm going out to shoot in a location that warrants it (down at the beach, for example) or in variable weather (especially windy and/or wet), I'll fit a filter to any lenses I'm taking with me. I still like the peace of mind and convenience of cleaning in the field, and I'm prepared to accept a very small impact on image quality in return, in those situations. Otherwise, I shoot without them.
** On wider angle, normal and short tele lenses, I see no discernable impact on resolution and bokeh when using Hoya HMC UV(c) filters. I can see a difference at longer tele focal lengths if I compare side-by-side, but it's really marginal... Almost like the difference between shooting with and without the AA simulator, only not quite so pronounced.
