Originally posted by m42man So you were using second-rate filters. There have been several reports (and examples) of this, on this forum, over the years. Regrettably, most filter brands fall into this category, to varying degrees.
I repeat - use one of the brands I've mentioned, or you will be disappointed.
All filters are very much not equal!
Here's an example of what happens with bad filters:
Lens Rentals | Blog
Even their "good" filter stack will have included several indifferent brands. Use one of the best brands (Hoya, Marumi, B+W) and even the most ardent pixel-peepers will be very hard pressed indeed to spot any degradation.
i may not spend big bucks on UV filters (and in anycase, "big bucks UV filters" may not necessarily mean "better results"), but i don't necessarily go for "cheapo" UV filters either (and in anycase, "cheapo" or "cheaper" UV filters may not necessarily mean "cheapo" or "cheaper" results, and not to mention, what is "cheaper" or "more expensive" etc? A certain price for certain filters may be "expensive" to me but could well be "not that expensive" to others).
Have used different filters before, including Marumi, B+W, Sigma DG, Hoya HMC UV, Kenko.
But, with some of the lenses, do see a difference between having UV filter on and filter off.
And decided won't use UV filter anymore.
What is my experience, may not be what others experience.
But, interestingly.
There was a lens in which i switched the rear drop-in filter.
Bought the lens preowned, it came with a certain brand of filter (wont go into what it is but it definitely aint a "cheaper" or "cheap" brand).
I switched that filter to a (relatively speaking) rather cheap UV filter (a Hoya HMC) and i got better results and left the filter in there.
(I switch becuz saw the filter in there had some surface scratches).
