12-26-2020, 04:10 PM   #1
smc Pentax Shift 1:3.5 28mm - Servicing movement at dovetail joint
Does anyone have any info about repairing/servicing this lens?
My smc Pentax Shift 1:3.5 28mm has a bit of flex at the point where the moveable bits slide against each other to achieve shift. It doesn't appear to affect IQ but the lens moves noticeably when handling as a sub mm movement at the mount results in a few mm at the front. Sorting it out, if possible, is probably good for the lens in the long term. If feels as if the slack will cause stress and wear.
So this is an unusual lens and I've not managed to find any info what so ever about the innards or how it fits together. I'm pretty sure the lens is a nightmare filled with minuscule springs and ball bearings ready to shoot across the room at the slightest touch of a screw
The affected part is the dovetail joint about 8mm from mount. The only reason I'm even considering repair is that it's so close to the mount. There is however likely to be some complexity even this close to the mount considering the lens ability to rotate.
This post is an initial feeler to see if anyone has any info. I expect good info to take a while to surface. I decided not to post any photos as I guess people knowledgeable will know what I'm referring to.
28mm servicing movement, close, info, k-mount, lens, mount, pentax lens, shift, shift 1:3.5 28mm, slr lens, smc, smc pentax shift
Machinery RC-135 'rivet joint' close up Top banana Post Your Photos! 8 12-04-2016 10:37 PM
Abstract Reflections in a Beer Joint Window Dewman Post Your Photos! 5 03-18-2016 03:00 AM
Nature Black Dovetail Kite, Australia asgr Post Your Photos! 3 04-01-2013 08:13 AM
Misc Joint Base Lewis-McChord Air Expo 2010 kcmadr Post Your Photos! 16 02-06-2011 02:49 PM
All times are GMT -7. The time now is 03:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
