01-18-2021, 07:14 AM   #1
Pentax-DA 35mm F2.8 Macro auto focus weakness
Hi,
I would like buy an Pentax-DA 35mm F2.8 Macro but I'm not convinced because I found written in the Pentaxforums review as follows:
<<"The problem occurs when you focus up close and then focus on a more distant subject; the autofocus seems unable to accurately focus">>
Link: https://www.pentaxforums.com/reviews/pentax-da-35mm-f28-macro/auto-focus.html
Please, can do you explain your experience regard this weakness/issue?
It's very important to me to get accurately focus becacuse I've to use this lens to portraits or people group shots.
I hope that this weakness regard only some production lot.
Thanks in advance for participating.
Antonio
01-18-2021, 07:58 AM   #2
amateur dirt farmer
pepperberry farm's Avatar
I've never experienced that issue with my copy of this lens...
buy it, enjoy it....
01-18-2021, 08:05 AM   #3
QuoteOriginally posted by pepperberry farm Quote
Thanks
01-18-2021, 08:21 AM   #4
tonyzoc's Avatar
The focus can be slow when going from infinity to close up, but it is a long throw. Working within a close zone...say 10-20 inches, mine focuses fine. It's a great lens and works well in manual focus too. Too bad it isn't full frame.
01-18-2021, 08:25 AM   #5
QuoteOriginally posted by tonyzoc Quote
Well! probably Pentaxforums has analyzed an malfunctioning item
01-18-2021, 08:32 AM   #6
luftfluss's Avatar
QuoteOriginally posted by antoniominturnino Quote
Hi,
Link: Pentax-DA 35mm F2.8 Macro Review - Autofocus | PentaxForums.com Reviews
Antonio
I have not had the AF issue described in that article. HD DA 35 Macro + K-70.
01-18-2021, 08:34 AM   #7
QuoteOriginally posted by luftfluss Quote
Thanks to your response.
Probably Pentax has solved the issue in the new HD version.
01-18-2021, 08:37 AM   #8
Larrymc's Avatar
Hi,
Antonio
The DA 35 Limited has the quick shift feature that allows you to manually get the focus "in the ball park" and then use the A/F so that the A/F throw is shortened or you can use the A/F and then use the quick shift feature to manually focus.
01-18-2021, 08:42 AM - 1 Like   #9
UncleVanya's Avatar
I don’t think the HD version is why this is more reliable now. The tests done were on the k200d and k-7. Autofocus in general is improved on newer bodies.
All screw drive macro lenses I’ve tried on Pentax can occasionally miss focusing and waste time racking back to minimum focus or the opposite. With quick shift you can bypass some of this. The problem isn’t typically that the lens won’t focus eventually, but that time is lost while it overshoots the mark and you wait for it to recover.
01-18-2021, 08:55 AM   #10
Hi,
Antonio
I have had this lens for years using with K3 and K5. Never had any focus issues with it. + it's amazing.
01-18-2021, 09:01 AM   #11
QuoteOriginally posted by Kwong Quote
Thanks
01-18-2021, 10:36 AM   #12
Seeker of Knowledge
aslyfox's Avatar
reportedly the only changes between the HD and SMC DA Limiteds are the coatings and shape of the aperture blades
HD vs. SMC Pentax Limited Primes
Introduction
HD vs. SMC Pentax Limited Primes Review - Introduction | PentaxForums.com Reviews
be warned
some of us find it difficult to stop at just one limited lens
the limiteds do they live up to the reputation and why - Page 26 - PentaxForums.com
01-18-2021, 10:58 AM   #13
kayakfari's Avatar
Rather than the lens itself, this 'issue' probably has more to do with Pentax AF in general and the way that 1:1 AF macro lenses function.
It could've been the reviewer's first time using a 1:1 AF macro, so maybe didn't know what to expect. It's a long focus throw from infinity to macro.
This is a solid and very sharp lens, works best for me on the K-01 !
Def get the HD version, and it will cover FF (at least in the close up range) according to this:
HD Pentax DA 35mm f2.8 Macro LTD: a quick report. - phillipreeve.net
01-18-2021, 11:02 AM - 2 Likes   #14
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by kayakfari Quote
interesting
this article does discuss the SMC version
Full Frame Coverage of DA Lenses: Comprehensive Test
Which DA lenses cover the full 24x36 mm frame?
By PF Staff in Gear Guides on Jan 7, 2019 . . .
DA 35mm F2.8 Macro Limited
Better (one grade higher) results at close focus settings
35
WO D
F5.6 C
F11 C
Read more at: Full Frame Coverage of DA Lenses: Comprehensive Test - Gear Guides | PentaxForums.com
01-18-2021, 12:02 PM   #15
tonyzoc's Avatar
It's a screw drive focus so not sure a new coating would make any difference...
35mm, 35mm f2.8 macro, f2.8, f2.8 macro auto, focus, k-mount, macro, macro auto focus, pentax lens, pentax-da 35mm f2.8, regard, slr lens, weakness
aperture weakness on SMC DA 70 limited. Help needed. Anybody experienced such issue? Tatouzou Repairs and Warranty Service 11 07-02-2017 08:27 PM
Weekly Challenge #308 - Weakness Hattifnatt Weekly Photo Challenges 15 12-16-2014 05:00 PM
A german Pentax Q user with a weakness for manual lenses GoldMark Welcomes and Introductions 4 01-10-2013 09:50 AM
Wanted - Acquired: DA 35mm f2.8 | FA 35mm f2 | DA 21mm f3.2 | FA 28mm f2.8 maximm Sold Items 2 03-10-2010 07:36 AM
A K10D/K20D weakness. Peter Zack Pentax DSLR Discussion 5 03-31-2008 11:18 AM
All times are GMT -7. The time now is 08:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
