Originally posted by DeadJohn The 16-85 and 18-135 are common upgrades from the 18-55. 16mm is quite a bit wider than 18mm. Both lenses are sharper than the 18-55.
But 85 is quite a bit shorter than 135mm.
I'd look at
DA 18-135
DA 16-85
DA 17-70 and those from other brands notably the Sigma
DA 20-40
Tamron or Sigma, 17-50
But how you go with those depends on if you wan OEM Pentax gear, water resistance, what focal length interested you etc.
For example the 16-85 is a great lens, but for me personally, 85-135mm is worth more than 16-18mm. And every one seems to love their 17-70s. It's all about what focal lengths are important to you.
My advice would be, if you have any plans of getting the DA 55-300 PLM then the 16-85 would be the best match for it. That will give you the best range and quality at an affordable price. I you're planing for a future with other telephotos, the DA 16-85 can't be beat. If you want a lens for one lens hikes that can do many different things, then the 18-135 gives you the best range without suffering from the lack of excellence many super zooms suffer from.
