Originally posted by mikesbike None of the Pentax "F" or "FA" 100-300mm lenses have a great reputation, but as MSL says, are generally good in their 100-200mm range
Yes, that's pretty much true of all the Pentax variable aperture zooms made for film cameras, and of consumer grade telephotos in general. Even the 55-300 PLM, as good as it may be at 300mm, is even sharper in the 55mm to 200mm range.
I briefly owned the slower aperture FA 100-300. I bought it for landscape use, believing it would be better in the 100-200 range. What I was surprised is that while it was sharp in the center at 100mm, it was not at all sharp away from the center, even when stopped down, on a cropped sensor. So not so good for landscape use. The lens does have a bit of a cult reputation, which I think arises from its compact size and the fact that it does produce images that have very attractive color.
The other Pentax 100-300 lens, which came both a power zoom version (the FA) and the later non-power zoom version (the F) is generally considered the worst of Pentax film era telephoto zooms. The FA-J 75-300 has nice color and there is decent edge to edge sharpness, even on an FF sensor, from 85mm to 160mm at f11. The best of these AF telephoto zooms is the FA 80-320. Even that lens doesn't have all that much resolving power at the long end of the zoom, though it's actually pretty good (better than the others) at the wide end, with nice sharpness, color, and surprisingly good rendering. But none of those old lenses can match, on an APS-C camera, the redoubtable 55-300 PLM.
