Originally posted by Viking42
Great tip on the black dot thing. Thanks, I will do that.
And you might be right about using this (or any other AF lens) in the landscape. There's so much stuff (branches, snow, stumps, grasses, logs) for the AF system to latch onto that it might be missing what I really want in focus. So that's why I started using center spot AF to see if I get better hit rates. I like that this lens supports quick shift, as fine tuning focus is easy. So the lens may indeed be fine, it could be just user error.
You're welcome. I also use the spot AF setting a lot for these type of photos. I think part of the issue with the 12-24 lens is that it has such a relatively large field of view as a wide angle. At 12mm , etc...it does cover a lot of real estate. Although that is just a guess on my part.
Another thing I do, when taking pictures of again vintage cars with large hood areas without AF spots.....is I sometimes will see a AF point...such as the hood ornament on the car's vast featureless hood, and I gently push down either the shutter button...without pressing the shutter completely down so I can 'lock' the focus, or I focus , then put my finger on the AE-L button (AE-Lock) when I find a AF spot to lock the focus, and then compose my picture of the large area without a AF point, but still within the same focus area, and take my shot.
