Knowing how a lens will render without buying the lens can be useful. I've always had a hard time getting anything out of looking at the MTF charts provided by lens manufacturers. Usually, MTF chart are provided for lens apertures wide open, I didn't find it very useful originally. But, I now think that I nailed it, having the lenses , what I see in pictures seems to correlate pretty well with the MTF charts provided by Ricoh. For instance the D-FA 28-105 and D-FA 24-70 render corners and bokeh differently, and this can be guesstimated by looking at their MTF charts (if my conclusion isn't wrong.. of course).
Below are links to the MTF charts provided by Ricoh for the D-FA 28-105 and D-FA 24-70 lenses:
HD PENTAX-D FA 28-105mmF3.5-5.6ED DC WR / Standard-Angle Lenses / K-mount Lenses / Lenses / Products | RICOH IMAGING HD PENTAX-D FA 24-70mmF2.8ED SDM WR / Standard-Angle Lenses / K-mount Lenses / Lenses / Products | RICOH IMAGING
The 28-105, e.g at 28mm , shows corners where image features look like smeared, this is very eye catching on a large print.
The 24-70 shows corners where the contrast of image features is softened, less attention catching on a large print.
While the DFA28-105 seem to be sharper than the 24-70 outside the center, the corners of the 28-105 are eye catching in large prints, and the 24-70 produces a more pleasing bokeh.
That difference can be seen in the MTF chart for the 30lp/mm lines.
There are two types of lines in the MTF chart: the S lines (Sagital), and the M lines (Meridional).
The S lines at 30lp/mm represent the detail contrast parallel to image circle radius.
The M lines at 30lp/mm represent the detail contract perpendicular to image circle radius.
So, when both S and M lines drop in outwards direction from the image center, detail contrast drop by the same amount is both S and M direction, which produced softened image feature.
When the S line and M lines gap increases in outwards direction from the image center, the amount of detail contrast drop isn't the same in S and M directions, which shows as if image features are being smears toward the edges of the image circle. I could observe this with the DFA28-105 and the 24-70, but my conclusion correlated pretty well with what I can observe on the DFA15-30 , DFA70-200 2.8 and DFA 150-450 (especially about how bokeh looks like). I haven't checked for the DFA 70-210.
I could confirm this finding by reading the MTF charts published by Ricoh, and knowing how my lenses render images.
Is my conclusion just by accident or not?
I know some people hate charts. But here , maybe is the chance to reconcile both image aesthetic and lab tests.
