11-17-2008, 01:06 PM   #1
Nesster's Avatar
Takumar 55/1.8: SMC and AUTO compared
SMC and AUTO Takumar 55mm f/1.8's compared. The SMC seems to have the front element recessed a bit more, you can also see how effective the SMC coating really is.
Note also how the aperture rings turn in opposite directions.
Photos taken with SMC Takumar 50/1.4
01-13-2010, 09:23 PM   #2
Just1MoreDave's Avatar
I just got one of these today. Great comparison photos. The Auto-Takumar has an interesting construction. Typical Asahi practice has the beveled trim "name" ring unscrew, revealing screws underneath that hold the filter ring on. On the Auto-Takumar, the "name" ring is threaded into the filter ring, but you don't need to remove it at all to access the front of the lens. The filter ring also is threaded. It simply unscrews, just like a filter. I've never seen that technique before. I don't remember ever taking apart a Super-Takumar, but definitely by the metal-focus-ring S-M-C Takumars, they used typical construction. The Auto-Takumar also has quite a lot of brass inside, which in later lenses is replaced by aluminum.
auto, compared, k-mount, pentax lens, slr lens, smc, takumar
SMC Takumar 85mm 1.8 Auto/Manual Switch Jammed Irishwiseguy Pentax SLR Lens Discussion 12 06-29-2010 11:36 AM
Takumar 300/4 vs K400/5.6 anybody compared? axl Pentax SLR Lens Discussion 2 06-04-2009 06:06 AM
have you ever compared the Takumar 85mm 1,9 with the SMC Takumar 1,8??? 1,8 & 1,4? beegee Pentax SLR Lens Discussion 5 02-14-2009 07:31 PM
Match 11: SMC Takumar 1:1.4 50mm vs. Sears Auto 1:1.4 f=55mm carpents Pentax SLR Lens Discussion 11 07-13-2007 10:17 AM
SMC Takumar 50/1.4 vs. Auto-Takumar 55/1.8 carpents Pentax SLR Lens Discussion 5 06-24-2007 07:55 PM
All times are GMT -7. The time now is 11:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
