Originally posted by Pentaxxoid Not resolution, but total pixels projected onto a sensor.
The problem is there are fewer of those "best" pixels. Would you still insist the same if we used a FF-lens on a phone-size sensor?
---------- Post added 02-12-21 at 11:52 AM ----------
Would you care to elaborate which step in my logic is faulty?
Your APSC body has a certain amount of pixels. It's the same regardless of which format lens you use. You could have your sensor seeing all of an APSC lens' image circle, or you could be cropping away half the FF lens' image. Either way, my K3 gathers 24 mpx worth of information.
These matters really aren't worth worrying about. Resolution and detail is a problem solved, for at least the past decade.
