Testing complete -- I took some shots of a bank of trees about 100 metres away from my balcony to check infinity focus; then another set of a print on the wall to check near focus (a high contrast graphic of some palm fronds, about 1.5 metres from the camera). Camera on tripod, self timer mode; aperture wide open; six shots each subject; first two were AF in spot mode; next two were manual focus through the viewfinder; last two were manual focus in LV, using 6x magnification. Here's what I found...
For the distant trees:
- Frames 1 & 2, AF, focus was off, trees not in focus; a car about halfway between camera and trees was in focus.
- Frames 3 & 4, manual focus in viewfinder, focus was worse; nothing was in focus; (this is very surprising as I am confident I nailed focus in the viewfinder).
- Frames 5 & 6, manual focus in LV, were spot on, perfect focus.
For the wall art:
- Frames 7 & 8, AF, focus was slightly off, print not perfectly in focus; close, but no cigar.
- Frames 9 & 10, manual focus in viewfinder, were again worse; focus was slightly off, but still worse than AF.
- Frames 11 & 12, manual focus in LV, were spot on, perfect focus.
A further note -- in all cases for the infinity shots (trees), the lens focus ring was not all the way over at full stop, even for the LV shots.
So what the heck is going on here? Clearly the lens is capable of infinity focus based on the LV shots of the trees. But why am I seeing perfect focus in the viewfinder but the shots are off, and in fact worse than AF? I thought I did a good job of shimming the new focus screen, but now I am questioning whether that might be the issue here. However, I am not having any such problems with other lenses, which baffles me. Perhaps I need to test them more thoroughly to see if they are off as well, in which case I need to check the focus screen shimming again and tweak. I mostly shoot at smaller apertures, so the DOF makes up for some error. But I still suspect it's the 12-24 lens that is problematic, especially when trying to hit infinity.
Any wisdom gleaned from the above tests is gratefully accepted. I'm scratching my head here a bit.
---------- Post added 3rd Mar 2021 at 20:38 ----------
Originally posted by kh1234567890 It is very simple. Camera on tripod, SR off, short timer release, centre point autofocus, wide open aperture. Find a distant contrasty object (at 12mm it won't have to be that distant), tree or a building, at the centre of the frame. Defocus the lens and shoot a series of shots, stepping fine tune by say 2 or 3 between shots and defocusing each time. Pixel peep on a monitor to find the best fine tune range. File size should also give you a hint, it will be largest for the most detailed frames unless things have moved or light has changed. Then repeat at single fine tune steps over the smaller 'best' range. Done.
AF on my DA12-24 on a K5ii is pretty reliable.
Thanks - that is indeed easy and straightforward. Upon further pondering, it seems I have a bit more testing to do to rule out some other factors before I go ahead with that -- first of all to see if other lenses are also missing focus; and if so, do a more rigorous test of the new focus screen. If all is well on both counts, then I will use your advice and have a go at the 12-24.
