Originally posted by Jodokast96 What end do you shoot more? 15mm on the short end is a lot easier to make up than 100mm on the long end.
I disagree, at least in part. Cropping can turn 200mm into 300mm easily enough. Although to be sure, probably half the time when 200mm isn't enough, neither is 300mm. So if you were going to crop anyhow, having to crop *more* could be problematic. But as I just mentioned in another thread, that 55-70 range one misses by using an 18-55 and 70-300 is actually a wonderful range for many kinds of portraits. And my sense was, the gap there combined with the increased size/weight of the 70-300 was such that I tended to put the 70-300 on for a few shots, then I'd want to take it off and get the 18-55 back. The 50-200 didn't often make me feel that way, because I could do more shooting with a lens that goes down to 50 than one that goes down to 70.
But if one's main concern is lens changes, and one doesn't need a "fast" (large maximum aperture) lens, and doesn't min spending a little more, the 18-250 is certainly a great choice too. IQ on all of these is pretty similar, really.
