Originally posted by evanleeson
Still puzzled about the max aperture issue.
Yeah, that's a strange situation. Normally the 1:3.5-4.8 printed on the front of the lens would indicate that at 28mm the max available aperture is 3.5, and at 80mm it's 4.8. But your aperture ring has a f/2.8 setting. Misprint on the front of the lens? Then the opposite side of the aperture ring shows four f-stop settings, and there's a screw by it. Could the screw be for setting the max available aperture to f/5.6 for instance? That way, when using the lens you can't go below f/5.6. Or maybe it's just an assembly screw that helps hold the lens together. Very curious.
Welcome to the forum.
You've tossed us a head scratcher. Maybe one of the many knowledgeable folks here on PF can enlighten us. At least you can brag that you own a 'star' lens!
