03-23-2021, 03:02 PM   #1
Curious about my Super-Takumar 55mm F1.8
Studying the detail for the lens on the lens review database, there are a number of key indications that it is an early version from the start of production in 1962.
It has fine ribs on aperture ring and the aperture ring has the smallest aperture to the right, i.e. the ring turns the opposite way of later models.
But the lens has a diamond as the settings mark and not the dot which would be in keeping with the early version.
Also when I tried to register the serial number on this site, I received an error saying that I'd put in the incorrect serial number and it should be 7 digits, my serial number is clearly 6 digits.
Any help on identifying the version of my lens and even better still a year of manufacture would be much appreciated. I have attached a couple of pictures of the lens.
Thanks Phil
03-23-2021, 04:25 PM   #2
D1N0's Avatar
Earlier super-Takumar 55/1.8 had six digit serials. Standard Super-Takumars - Takumar Field Guide this site has extensively researched batches of takumars
03-23-2021, 05:30 PM   #3
Otis Memorial Pentaxian
Welcome to the Pentax Forums!
QuoteOriginally posted by Phil64 Quote
Interesting! Does yours have the "flat" style focus grip or the later "hill/valley" grip? What is your serial #? (Mine is the early type pictured here on PF in the collage view photo. Its serial number is 823885.)
03-23-2021, 08:44 PM   #4
MSL
MSL's Avatar
You should be able to enter the serial number by adding a leading 0. See here
Serial Number Database - PentaxForums.com
03-24-2021, 01:46 AM   #5
QuoteOriginally posted by D1N0 Quote
Thank you. I've now added it successfully to the database by adding a zero to the begining of my serial no.
---------- Post added 03-24-21 at 01:47 AM ----------
QuoteOriginally posted by MSL Quote
Thank you, successfully added now.
aperture, camera, database, k-mount, lens, pentax help, pentax lens, photography, slr lens, super-takumar 55mm, troubleshooting, version
$10 vs $1000 or Takumar SMC 55mm F1.8 vs Sony Zeiss FE 55mm F1.8 kindakaa Pentax SLR Lens Discussion 107 04-03-2016 02:59 AM
Super Takumar 55mm F1.8 vs DA 50mm f1.8 hjoseph7 Pentax SLR Lens Discussion 10 05-11-2015 09:54 AM
Mamiya / Sekor 55mm f1.8 or SMC Takumar 55mm f1.8? -kb- Pentax SLR Lens Discussion 14 09-16-2009 05:54 AM
Super Takumar 135mm f/3.5 and Super Takumar 55mm f/1.8 Fixcinater Pentax SLR Lens Discussion 21 08-30-2009 09:34 AM
All times are GMT -7. The time now is 06:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
