Originally posted by figmental1978 anyone else with the 44-2 with a genuine pentax M42 adaptor? when the 44-2 is screwed on, it doesn't touch the flange of the camera body, just the adaptor which causes it to wobble, is this normal?
Actually, this irritates me. I have three adapters, a genuine Asahi adapter, a Kood adapter, and an un-named one (rather, it is so old, the name has rubbed off). The last one is useless, the flanges are slightly the wrong size. The other two I use a lot.
I use the genuine one with all of my Takumars, and it works fine, except for one of my Asahi extension tubes where I get the wobble. Interestingly, the Helios 44M I bought recently does not have the wobble.
I have a CZJ 135/3.5 and 35/2.4 and both of those wobble with the Asahi adapter. With the Kood adapter, there is no wobble.
The reason appears to be that when the lens (or extension tube) is fully screwed into the genuine adapter the end of the screw thread on the lens is achieved before the back face of the lens is in contact with the camera mount. You cannot screw the lens any further in but there is still a small gap between the lens and mount. The wobble is the slight play in the adapter locking spring (and mount catch). One solution with the Asahi adapter is to use a shim (the bits of metal in security tags are great for this), and if you put the shim over the electrical contacts then you'll also get focus trap. The problem is that if the lens is not completely screwed in, then there is a chance that you'll not get infinity focus.
However, I find that it is better to use the Kood adapter because I can then screw the lens in further in the mount, and get a complete contact between the lens and mount.
I have to mention that I have removed the spring off my Kood adapter, and I have drilled a hole for the camera locking pin in the Flektogon. If I use the Flek with the Asahi adapter I find that the locking pin does not engage in the drilled hole, further indicating that the lens is not fully screwed in.
Richard
