04-08-2021, 09:10 AM   #1
LittleSkink's Avatar
reducing purple fringing in HDR with 10-17?!
Been playing with HDR and 10-17 fisheye zoom, its fun but quality is not great - purple fringing especially
I shoot RAW, 3 shots (+2 / 0/ -2) and process with Affinity. In high contrast corners purple fringing is so bad Affiinity cant remove it
For HDR stacking would a tripod make much difference to things as currently I hand hold?
04-08-2021, 10:27 AM   #2
Otis Memorial Pentaxian
Sadly, PF is a known trait of the DA 10-17 Fisheye, something that is frequently noted on the Fisheye Fever thread (LINK). In regards to PF and HDR, I recommend removing after merge, being aware that PF tends to be worse with overexposure (smaller bracket increments might be in order). I also strongly recommend tripod use for HDR and any other situation where merging frames is done.
I am an Affinity Photo user, but not for that purpose and can't help there.
04-08-2021, 10:54 AM   #3
Fogel70's Avatar
I agree, avoid blown out highlight is probably best way avoiding severe PF.
You can try dialing in some negative exposure compensation, maybe one or two stops.
So the HDR in effect becomes +1/-1/-3 or 0/-2/-4 instead, and then bring up the shadows in post.
Or shot 5 images instead and not use the 1-2 highest exposed shots for the HDR, if they show too much PF.
04-08-2021, 11:09 AM   #4
QuoteOriginally posted by Fogel70 Quote
Thanks for this suggestion. I was going to add something similar, but am glad I didn't because you did a much better job of saying how to do it.
hdr, k-mount, pentax lens, slr lens
Nikon reducing from 17 to 2 repair centers in USA DeadJohn General Photography 32 03-09-2020 08:40 AM
Reducing colour fringing with Digital Camera Utility EFats Digital Processing, Software, and Printing 7 12-01-2019 01:46 AM
Use of UV filters to reduce purple fringing? BigMackCam General Photography 23 11-11-2019 02:50 AM
DA 10-17 purple fringing rpriedhorsky Pentax SLR Lens Discussion 13 02-07-2009 04:46 AM
10-17mm fisheye and purple fringing darthku Pentax SLR Lens Discussion 12 06-03-2008 10:28 AM
All times are GMT -7. The time now is 04:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
