Originally posted by robbiec Doesn't the 70-200/2.8 or 70-210/4 cover those at the moment? Let's suppose that something in the 105 to 135 is in design, will they go via the Limited series like a 120/2.4 or DFA* and a no holds barred 105/1.4 or 135/2 - which would be a better halo product? because that's what these are.
Agree completely that a 24 prime was needed, until the 21 Limited was announced. We've a couple of zooms touching 24 and a Limited that also covers it so the heat is off that focal length.
I'm not seeing std primes coming out anymore other than run outs or value focused offerings. I think it will be Limited, D(F)A* or Macro series from here on in. So going back to my original proposition
HD D FA50/2.8 DC WR MACRO to be perhaps followed by the HD D FA*200/4 ED DC AW MACRO to finish off the trifecta of FF Macros as being a
realistic addition to the lens road map.
If they do premium (DFA*) lenses, and I suspect that is the likely route given recent developments, then we would be seeing maximum apertures in the f/1.8 range with a 105 or 135.
A 24mm is still needed. There is quite a bit of difference between 21mm and 24mm, nearly 8º if I recall correctly. A DFA*24/2 would be a logical focal length and build. Heck, even though I consider it to be a useless focal length, a DFA*28 f/? would be a better choice for fleshing out the lens line.
As far as focal lengths being covered by zooms, that just doesn't cut it. As big as the 85/1.4 is, it is dwarfed by the 20-200/2.8, and is two stops faster. It's not that much different in size from the 70-210/4, but is 3 stops faster.
The 50/1.4 is covered by the 24-70, and there is still the FA50/1.4 and the 43 in the line, so what was the point of the new 50?
If you are talking about the heat being off a particular focal length, there already is a perfectly workable 50mm f/2.8 macro in the line up. There are lots of better places for them to put their resources than in lenses that they already have.
As an aside, I can pick up a new DFA50 macro for under Can$400.00 (under US$320.00). is it worth doing?
