04-19-2021, 08:15 PM   #1
HD Pentax-D FA 24-70mm F2.8 barrel wobble?
I just received a used HD Pentax-D FA 24-70mm F2.8 that appears to be in excellent condition. However, there's a bit of play between the zoom ring and the lens barrel throughout the zoom range except at 70mm. Not a huge amount of movement but it does rattle a bit. Can anyone tell me if this is normal or anything to be concerned about?
Thanks in advance,
Peterman
04-19-2021, 09:23 PM   #2
If you can rock the front back and forth I would worry. What you are describing probably not so much, but info from an owner is more reassuring.
04-20-2021, 12:11 AM   #3
i_trax's Avatar
Hi , I also just received an used DFA 24-70.
It is a very fine lens indeed , a bit heavy and large for my liking , but...
It has an external zoom so obviously there is some "wobble" present but it is not really noticeable , it is much smoother than , for example , on the DA* 60-250.
I can not notice any diference between 70 and other zoom range positions.
If I compare it with the DA* 11-18 ( an absolute marvel of the engineering ) , of course there will be the noticeable diference, the DA* has internal zoom and focus.
04-20-2021, 12:18 AM   #4
Michail_P's Avatar
As far as I know, some woobling is normal for external zoom lenses. If itís too much, you will probably notice it in the focus of the photos.
04-20-2021, 06:22 AM   #5
QuoteOriginally posted by Michail_P Quote
The front will rock back and forth just a bit. Would be difficult to measure (1/2 mm or less) but you can see it. Enough movement that it will be audible walking around with it mounted. Fully extended at 70mm the wobble is pretty much gone, which is the opposite of what I'd expect.
For reference, my 60-250 is tight throughout the zoom range. However, my DA* 16-50 does have a bit of play in the barrel and even my DA 12-24 wobbles just a bit. I never noticed the play in either of those until I checked them out for comparison. ��
So...since the 24-70 is a Tamron design, perhaps the tolerances are not as tight as a Pentax Star lens? I'm concerned that decentering could be an issue, so I will take some test shots to evaluate.
24-70mm, 24-70mm ed sdm, 24-70mm f2.8 barrel, barrel, bit, f2.8, fa, fa 24-70mm f2.8, hd pentax-d fa, k-mount, pentax lens, pentax-d, pentax-d fa 24-70mm, play, slr lens, wobble
Barrel wobble in DA 24-70mm cpritchardv Pentax SLR Lens Discussion 3 10-10-2016 12:30 PM
Sigma 17-50mm 2.8 barrel wobble? wowarning Pentax SLR Lens Discussion 5 06-04-2014 09:26 AM
measuring DA 16-45mm barrel wobble tibbitts Pentax SLR Lens Discussion 7 02-24-2014 09:38 AM
Used FA 43mm lens barrel wobble - is it normal? hagiri_11 Pentax SLR Lens Discussion 7 04-25-2012 09:57 AM
Pentax SMC-M 50mm f1.4 lens barrel wobble Dan Chang Pentax SLR Lens Discussion 8 12-30-2011 10:22 AM
All times are GMT -7. The time now is 08:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
