Originally posted by pentax_amateur I focused via the viewfinder because this is how I focus while taking shots other than "bills on a wall". I am interested to find out what lens I should use when focal distances overlap.
Originally posted by pentax_amateur I was debating this with myself and decided to put all widest apertures into the same pile because when I don't have enough light, I open up the aperture to the widest, whatever it happens to be on that lens. If the aperture is there, it should perform.
Respectfully, while that might represent how you use lenses, it also ensures that the comparison, in general terms, is unusable. Especially if you didn't Fine Adjust the AF.
Using the viewfinder, the only way to measure sharpness the way you did it would have been to adjust AF, then take a series of 5 or 10 pictures for each lens.
Also, as I said before, if you didn't use the same apertures, you're not comparing apples to apples.
Originally posted by pentax_amateur Agree, but if a lens fails miserably at sharpness, then nothing else matters.
"Fails miserably" is an exaggeration.
