I suggest that the OP concentrate on what photographic goals exist
does a wide angle lens serve
the 15mm and 21mm comes to mind
31mm is very close to the top of the old range ( 35mm ) for a wide angle
and then you have the factor of the ASP-C sensor to consider
I would urge the OP to consider what this article says about the " differences " between the SMC and HD DA Limiteds
Quote: HD vs. SMC Pentax Limited Primes
Introduction
At Photokina 2012, Pentax announced a brand new lens coating which they named the "HD Coating". This coating is slowly starting to replace the conventional "Super Multi Coating" (SMC) on high-end Pentax glass. According to Pentax, the new HD coating greatly reduces reflectance without making any sacrifices in terms of durability. This kind of coating isn't new to the industry, however: Pentax digital medium format lenses have been treated with a slightly less durable variant called Aero Bright coating ever since their debut, and other manufacturers have been using "nano" coatings on their premium lenses for several years.
The modern SMC coating that DA lenses have been using for about a decade now isn't the same as the SMC coating that Pentax originally launched in the 1970's. In fact, most DA lenses have been said to have a "ghostless" coating, so while we don't expect the difference between SMC and HD coating to be be a game-changer, it should certainly still be easy to observe.
Read more at:
HD vs. SMC Pentax Limited Primes Review - Introduction | PentaxForums.com Reviews
I have chosen to stay with my SMC DA versions
will the change from SMC to HD in the FA Limiteds make more difference, we don't know yet
confession time: I have trouble accepting the F DA and the Zoom into the Limited family
