05-01-2021, 06:08 PM   #16
Great lens. Had mine for 4 years now with no problems.
05-01-2021, 06:47 PM   #17
UncleVanya's Avatar
QuoteOriginally posted by caliscouser Quote
Not sure anyone addressed this. But I believe the K100d can and the K-3 / KP can't.
Awesome lens by the way, image quality is absolutely top notch.
Correct. My favorite conversion body is a k100d.
05-01-2021, 07:17 PM   #18
This is interesting. I recall when the K100D Super came out, the primary upgrade was for using the new SDM lenses, while the K100D was said to be incompatible with these lenses. So many people thought the new lenses would not AF at all with the K100D- but now I guess they could, but via screw-driven instead of SDM.
05-01-2021, 07:41 PM   #19
UncleVanya's Avatar
QuoteOriginally posted by mikesbike Quote
Only those five. The others that only have sdm fail to af. The k100d has the power zoom contacts so it isn’t clear precisely what hardware has differs from it to the super version.
05-02-2021, 05:49 AM - 1 Like   #20
5ks
5 DA* lenses were made to work on both screwdrive only and sdm cameras. They were setup to use with both systems but there wasn’t any way on the sdm cameras to tell them to NOT use sdm even if the sdm had failed. By programming the lens you can have it lie to the camera and trick it into thinking it is not sdm compatible at which point the camera uses screwdrive. Only four of the five lenses made specifically with screwdrive and sdm can be converted the da* 16-50, 50-135, 200, and 300. The 60-250 behaves weirdly and is unreliable if you attempt conversion.
Thank you for the additional info. Wonderful to see people having such knowledge.
drive, f4, failure, k-mount, lens, pentax lens, screw, sdm, sdm 300 f4, slr lens
Russian 300 f4.5 Photo-Sniper vs Pentax 300 smc f4 JimboWalker Pentax SLR Lens Discussion 6 12-23-2020 07:23 AM
Advice requeseted for concerns with my Acratech Ball Head QR Clamp david94903 Troubleshooting and Beginner Help 11 05-15-2019 09:34 PM
The new HD DA 55-300mm F4.5-6.3 ED PLM WR RE and focus breathing concerns anu l Pentax SLR Lens Discussion 2 12-09-2016 08:19 AM
16-50 SDM concerns DeadJohn Ask B&H Photo! 2 12-15-2013 08:54 AM
645D, K-m2 and NEW LENSES DA*10-16/4 SDM, DA*20/2 SDM, DA*28/2 SDM ogl Pentax News and Rumors 165 08-11-2010 03:26 AM
All times are GMT -7. The time now is 11:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
