Originally posted by jimmypage It's not that I think 24mp goes beyond the resolving power of the lens, but that if I have a pic that I think can benefit from DSLR scanning beyond 16mp, I will have it drum scanned. There is already no way for me to scan at 24mp due to difference in aspect ratio.
Just to clarify, in case I muddled my explanation in my first post, I was proposing that you shoot slightly more than half your neg with the first shot (call it Frame 1, being the top half the neg, for example), then shift the neg and shoot the other half with a second shot (call it Frame 2, the bottom half), leaving a bit of overlap between the two images so that the stitching software has something to latch on to in both. Convert both to TIFF, import into Microsoft ICE (or equivalent), and stitch them together to make a single image with significantly higher resolution than a single shot. This way you can use the full width of your K3 sensor for both shots.
So if you do this two-shot and stitch method you will far exceed 24MP -- probably 36 to 40MP depending on how much overlap you have. And then proportionally more again if you use pixel shift for both of those. I think you may actually get as good or better results than a drum scan using this method, if done well. It is remarkable how good DSLR scanning can be.
Hope I explained it better this time, but if you're interested in more details just let me know.
