Originally posted by jerryleejr it’s a large amphitheater…
Same here- the last, a friend's graduation was in 2011, and in a huge indoor arena. Furthermore, through a team-mate's connection, we were in a fancy exec suite with its very large windows but also its own balcony. There were seats inside and outside. This put me way up at the farthest distance, but sideways to the stage. Normally, at HS graduations, where I could shoot from a much closer position, I would just take a superzoom and use flash. But for this situation I took some big guns, with faster aperture capability. I also took a powerful hot shoe flash unit. Luckily, I was on the side of the stage where the graduates would be crossing facing me. I had plenty of time to do test shots, as there were several university officers, etc. giving speeches first. I had my DA* 50-135mm, DA* 200mm, and FA* 300mm f/4.5 along, and my DA 18-135mm superzoom for family shots after the event, which worked out beautifully. I used the DA* 50-135mm first with flash as the graduates filed in at closest range. Then, based on my test shots, I found my DA* 200mm best for framing the stage activity. I got some good shots of my subject using my biggest flash, all the way across on the other side while waiting in the shadows to go up onto the stage, boosting ISO to 800, and the lens wide open. But for the actual stage shots, the lighting was like spot lights but more of them, and quite bright. So then no flash, and I could use a smaller aperture. In addition to being handed the diploma, I nailed the very moment of handshake with the dean just after receiving the diploma, facial-expression and all- a good closeup of them with a bit of surrounding context. All this from sitting high up in a seat on our balcony. The family was thrilled.
But you "might" be able to move around some, which can allow more options as to equipment. Best to try some test shots if you can, to determine your best position. In my case, there was a pro photographer with his setup in advance, so I knew which way the show would be moving. I also advise using a FL that will give you extra room around your actual framing, in other words, frame your shot with just a bit more room than you need, and then crop a little in PP to determine the best composition.
