11-24-2008, 12:56 AM   #1
SOLVED. Nitec relay lens .What does it do?
SOLVED!! Hi, This is a relay lens by Ni-Tec inc. Part #sd00383
One end is labelled 'to 35mm camera - magnify" the other end "to 18mm camera - minify".
Any ideas as to what it does/how to use it/where it mounts?
11-24-2008, 02:56 AM   #2
Damn Brit
Guest
I believe it is used as the 'go between' for connecting a video camera to a microscope.
11-24-2008, 04:50 PM   #3
That would make sense as it is originally from a research facility that studied bugs and little critters.
Presumably, as it is labeled (Factory label) for 35mm or 18mm camera then it could be used between a film camera and a microscope.
I am off to look in the junk box as I am sure I saw an old(simple) microscope there.
If I can find it I will give it a try and post back.
Come to think of it I have a book on microscopes somewhere, will hunt it out and see what it says.
Thanks for the lead.
EDIT.
Yes, found the old microscope and after some fiddling (removed eyepiece, removed 1/2 tube, placed adapter between tube and relay lens then mounted other end of relay lens to camera via k-mount/m42 adapter) it worked!!
Thanks again for the pointer in the right direction and yes, one of the screw-on rings it came with can only be a sleeve to mount a video camera but I am happy to have got it working for film.
camera, k-mount, lens, pentax lens, relay, slr lens
Streets Vancouver 2010 Olympic Torch Relay esman7 Photo Critique 4 02-15-2010 03:17 PM
Sports Olympic Torch Relay bikecoboss Post Your Photos! 2 02-08-2010 03:49 PM
The big Relay race Falcons Post Your Photos! 3 09-19-2008 08:03 AM
All times are GMT -7. The time now is 03:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
