Originally posted by stevebrot There is lots of good information above, but there is one bit that I did not see that is part of my routine. I have found that stop-down metering is more consistent and accurate in live view than when using the optical viewfinder. With camera in M mode, I meter the subject in live view and switch back to the optical viewfinder for actual shooting. Those settings should remain good until either the light or the subject changes.
The other way is to use the histogram in M Mode, and shoot a tree trunk, pathway or anything else you consider to be about 18% grey and adjust settings until the histogram peaks in the middle. Then leave these settings until light changes.
I used to shoot in manual a lot with my PZ-1 and always metered off trees with spot metering
