Originally posted by lotech Hi there,
I read note about the Tessar 50/2.8 rear element may hit the SLR mirror so only recommended for mirrorless, I've only used the Pentacon 50/1.8 and have no problem, I wonder if anyone has actual experience with the Tessar on the Pentax K digital, there are couple different versions of the lens which one should I go for ?
Hmmmmm...are you talking APS-C or 35mm FF?
I own a CZJ Tessar 50/2.8, black, of late 1970s vintage (came attached to my Praktica LTL3) and it has no mirror clearance issues when adapted on my K-3 or on my K-mount film SLRs. Its aperture actuator pin also clears the K
AF2 power contacts in the K-3's mirror box. The only M42 or K-mount body on my shelf that it does not mount cleanly to is the Spotmatic F, but that is not unexpected.
That said, earlier versions with auto aperture (zebra and silver) as well as pre-set versions might be less friendly.
What cautionary note did you read?
