Originally posted by Just1MoreDave The AF is probably too slow for shots from a moving vehicle - I know this is true for my copy. It's not bad to manually focus.
I plan to keep the lens focussed on infinity permanently in manual mode. So this should not be an issue.
---------- Post added 05-24-21 at 09:21 PM ----------
Originally posted by mikesbike This has not been proven in images. As you are in an airborne moving vehicle, you will need substantial shutter speed for clarity in your shot, so you will need higher ISO regardless. Any of the vintage lenses can produce green or purple fringing in high contrast situations. I have often used the FA 77mm for night shots, or just after sunset with fine results. Just lucky, I guess. But with a 50mm lens on your K-1, you will get much more in your shot than with the FA 77m lens. The "F" or "FA" 50mm f/1.7 is pretty good wide open and yet better at f/2, better-performing than the FA 50mm f/1.4 at these larger apertures. You might even consider a DA 40mm lens wide open, if available. You can of course run test shots at night when on the ground.
Thank you. The saving grace is that the IBIS of K1 is excellent. I could get reasonably sharp images even at 1/90 sec with FA 77mm at f1.8 with ISO at 12800. I need to get at least one stop extra, preferably two, so that I can get the ISO down to 6400 max and maybe the shutter speed up at about 1/150 or so. That would be pretty good I think.
FA 77mm is a joy to use and the images are sharp when everything like shutter speed, chopper vibrations and luck falls in place. But the purple fringing around every single big point source of light is just ghastly. I have shot from air twice already. The images would need a great amount of tedious PP to get rid of all that purple unless someone knows how to handle it in a few clicks. I don't. In fact I am just average in PP. Perhaps I should find an expert to do this for me.
---------- Post added 05-24-21 at 09:27 PM ----------
Originally posted by kiwi_jono It may not be helpful but I have A 50 f1.2 and the FA 50 f1.4 and from my experience these lenses are not their best wide open and infinity and better focusing wide open on subjects say < 10m.
However that said my A 50 f1.2 seems to be say a stop better than FA 50 over the range of f1.4 - f4. By that I mean if I stop down the A 50 to f1.4 the IQ is more like the FA 50 at f2 (and in fact I quite often use the A 50 at f1.4 when I'm looking for better sharpness). Still probably not enough for you at infinity though.
Thank you. This is somewhat encouraging. I will try out the A 50mm at f1.4 and f1.8 when I get it hopefully next month.
I wonder if some of the AI based software could tackle the softness issue at infinity.
---------- Post added 05-24-21 at 09:36 PM ----------
Originally posted by UncleVanya Photons to photos does show a dynamic range advantage for the k3iii over the k-1ii the difference is at iso 12800 about a half stop. The k-1ii is about 1 full stop better than the k-1 at that same iso. This isn’t consistent across the board and at base iso the k-1 models outperform the k3iii. Put another way. At iso 12800 the k3iii should perform like the original k-1 set to iso 4000 or so as far as dynamic range is concerned.
With that in mind a 1.5 stop gain in dynamic range is very nice but the iso may still need to go up farther to get the shot.
I haven't seen any real world reviews of high ISO performance of the K3iii, or its comparison with the K1 or K1ii. But from what I have gathered, including in an interaction with a Pentax Ambassador, is that despite being an APSC sensor, the K3 iii is better at high ISO than the K1 ii and certainly the K1.
So if ISO 12800 on the K3iii is as good as ISO 4000 on K1, that's fantastic news for me, under the present circumstances
Of course, the shadows can simply be absolutely dark. It is the lit portions of the city (roads, buildings etc) and the patterns they exhibit when seen from the air that matter. If the noise at ISO 12800 is better for K3iii, it would be excellent because I will get one extra stop to play with.
---------- Post added 05-24-21 at 09:42 PM ----------
Originally posted by Andrea K f/1,2 and f/1,4 lenses from the past era aren't built to have sharpness wide open... above all in the borders
Thanks Andrea. Looks like the film era lenses are a non-starter for this application. I will need to concentrate on one of the latest Pentax DFA* 50mm or Sigma 35mm f1.4.
---------- Post added 05-24-21 at 09:53 PM ----------
Originally posted by pinholecam I gave it a quick try yesterday night with my FA50/1.4 (have the K50/1.2, but did not try it ).
Assumed the settings TAv mode, 1/250, f1.4
The so called infinity for my lens wasn't even acceptably sharp (it may vary copy to copy; but I would say don't assume what you have is better (best to try it beforehand ) )
ISO was something like 20K on that setting (can be 12K if exposure -ve compensating for the shadows )
f2 is probably acceptable for smaller images and infinity focus seems correct.
f2.8 and ISO was a bit too high imho vs f2 (so the lens got sharper, but the grain went up to a point that I feel ended up to be worse )
Remember, I am assuming 1/250 and not compensating for shadows.
If you do both (eg. -1ev, 1/125, you get back 2 stops which can go to f-stop and/or ISO )
Thank you. It's the eternal struggle between stopping down to make images sharper and reducing effects of lens aberrations versus getting grainy images at high ISOs. Some sort of golden mean needs to be found where the images are acceptable if not the best that they could be. The only other alternative is to get a Fujifilm 100 with their 80mm f1.7 and mount it on a suitable Kenyon Gyro. Unfortunately, that is neither possible under the present circumstances nor is it the most cost effective solution.
1/125 sec on a digital camera with 5+ stop IBIS at ISO 12800 and f1.4/ f1.2 on a modern digital lens with advanced optical design and coatings seems to be emerging as the Go To solution.
---------- Post added 05-24-21 at 10:06 PM ----------
Originally posted by Sandy Hancock If sharpness wide open is important (and I guess in this situation it is), the Sigma 35/1.4 Art or the DFA* 50/1.4 will suit you perfectly.
The Sigma is much cheaper, as well as giving you a wider field of view.
I also have both the FA 50/1.4 and A 50/1.2, and neither would be my choice for this assignment. Softness wide open, relatively poor edges, and chromatic aberration are all significant minuses.
Thanks Sandy. Looks like the Sigma 35mm f1.4 Art on K3iii is the best possible compromise, with effective field of view of 52mm on full frame. It will certainly be better than my present combination of K1 with FA 77mm f1.8, and should give me around 1.5 stops advantage, which I can use up on reducing the ISO or increasing the shutter speed. A lot depends on the ambient wind conditions on the day of shooting. I have experienced days when there are no air currents and an experienced pilot can glide the chopper with minimum vibrations. Those are the best of times and one needs a certain amount of luck for those times
Unfortunately the guys using the images haven't allowed me to display the aerial images anywhere for now. I would love to share some of those on this forum as soon as they allow me to.
