Originally posted by steephill The DFA* 50mm f1.4 would be much better than either of those older lenses. Edge and corner performance of the older lenses is poor wide open and the f1.2 has a distinct glow wide open. However if you have to go with one of the older lenses I would suggest the A50f1.2 stopped down to f2 and let the ISO rise, the K1 will perform well.
Hi,
I have the K1 and I tried it last time with FA 77mm wide open at f1.8. ISO at 6400. The results I got with shutter speeds as low as 1/90 sec with the expert pilot trying his best to reduce the vibration to the absolute minimum. The IBIS worked well. The images were sharp. But the light intensity of the city is pretty low (not like say NYC or Tokyo or London etc) and the images were not as well exposed as I would have liked. And the big city lights had horrendous purple blobs around them. Maybe the modern HD coatings of the new DFA 77mm would help control that. The old FA 77mm is absolutely superb during daylight, but looks like it can't handle so much contrast as in the city lights.
Ideally a f1.2 lens will give me one stop more light. That would certainly help. But I understand that the old lenses are quite soft wide open. So maybe stopping down to f1.4 or f1.8 would help. But the purple blobs would still be there in my opinion.
So maybe the DFA* 50mm is a good via media if used on the K3 iii. Of course it will have an effective field of view of 75mm, but I am OK with it. I can manage to move the chopper around to get the angle and field of view that I need. I don't know if the Sigma 35mm f1.4 is as good as the Pentax DFA* 50mm f1.4. If it is, its field of view at around 52mm on the K3 iii will be better for me than that of the DFA* 50mm. And I really need to do something about those big purple blobs around point sources of light.
---------- Post added 05-23-21 at 11:16 AM ----------
Originally posted by zapp You will realize that f/2 and even f/2.8 will be quite sufficient. A colleague of mine did aerial mapping with with Canon 5d and 2/35 to map street illumination at night. Windows, lamps, … are quite bright at night. High ISO performance of K1 should outclass the 5d, so don’t go wide open in the first step.
DFA50 will offer best corner to corner sharpness if you do area based mapping. Currently your discussion is only f-stop based. Do you really need 50mm focal length? For mapping of areas, 35 mm will work better.
As I said earlier, the city isn't very brightly lit. So any fast lens giving good wide open performance focused at infinity would help me. Or else, if the K3 iii does as well at ISO 12800 as does the K1 at ISO 6400, I could then be in a sweet spot with such a lens. I heard a lot of good things about the Sigma 35mm f1.2 on Sony E mount.
And I am shooting streets, monuments lit up at night etc. So a 50mm to 75mm field of view is manageable, while a 35mm field of view would be the best.
The K3 iii is supposed to surpass even the K1 ii in high ISO performance, and it would also help me in wildlife photography, which is another genre I love. Hence getting the K3 iii would be better than getting the K1 ii in my opinion.
I also thought of the Kenlab gyro. But I am not fully convinced about it for this application and getting it to Asia in the Covid times is going to be difficult.
---------- Post added 05-23-21 at 11:19 AM ----------
Originally posted by Henrico I own the K1.2 which is optical identical with the A1.2. This lenses suffer some field curvature, in the center infinity is spot in calibrated, in the far edges the highest sharpness available is found a little before infinity. The M1.4 (optical identical with the FA1.4) shows a similar behavior.
These lenses were made for object isolation nearby wide open, they deliver enough center sharpness for that use. At infinity they are a bit soft and hazy wide open. From F2.8 this gets much better and from F4 they perform almost as good as their modern siblings.
Wide open you also can expect a lot of aberrations like coma. Although not at infinity the picture attached shows that perfectly.
Thanks Henrico. This will help. The picture tells the story perfectly.
---------- Post added 05-23-21 at 11:28 AM ----------
Originally posted by UncleVanya I concur with the analysis of others so far. The 50mm f1.4 lenses from the FA and older series are very soft wide open and unsuitable for really sharp edge to edge shots wide open. The. DA* SMC 55 f1.4 is a little better but still isn’t in the same league for this type of use.
For my own use, The limited wide open performance can be used to creative effect or simply subject isolation, but that’s not what you are likely to want in this case.
The k3iii being a crop camera will make the dfa 50 mildly telephoto. Is that the right choice for this shot? I have no clue, but you should evaluate that before going up in the air. The K1 mk II might be a better choice. The Sigma 35 f1.4 is another lens to consider as this is a full frame fast lens with a wide angle of coverage and a reputation for good edge to edge sharpness. On apsc it will give you the “normal” lens field of view and on full frame a bit wider.
In any case good luck with the shoot.
Thanks UncleVanya for valid points as always. Due to the conflicting requirements (since you can't have it all), I am OK with FOV upto 77mm on full frame or APSC. What I need is reasonable sharpness at very large apertures, minimum lens aberrations in very high contrast lighting situations and best possible high ISO performance. If the Sigma 35mm f1.4 is almost as good as the Pentax DFA* 50mm f1.4, then I will take the Sigma. It appears that despite its large aperture, the Pentax 50mm f1.2 won't be of much use for my purpose.
---------- Post added 05-23-21 at 11:30 AM ----------
Originally posted by ismaelg It is more complicated than that but my simplistic suggestion: Whatever lens you choose, shoot at least 1 stop from wide open (~f2.8), careful focus at infinity and crank up the ISO as needed like there is no tomorrow.
It is easier to deal with noise in PP than "wide open lens softness"
Thanks,
Thanks Ismael for the valid points.
---------- Post added 05-23-21 at 11:38 AM ----------
Originally posted by tuco I say tonal scale is often more important than noise. Cranking up the ISO gets you low dynamic range and poor tonal scale. Pick your poison.
Yes indeed. For such applications like night aerial photography, there are lots of compromises to be made. You get something, but then you need to sacrifice something.
Sony A7 iii with Sigma 35 f1.2 seems the best compromise. The next maybe the Fujifilm 100s with the 80mm f1.7. But I really don't want to invest into another system. So sticking to Pentax, the K3iii with DFA* 50mm f1.4 or Sigma 35mm f1.4 seem the best compromise. This assumes that the K3iii is substantially better than the K1/ K1ii in high ISO performance.
