Originally posted by jcsnyc Just got a new DA 300mm and I have to adjust to -10 for focus (maybe needs -11).
Thoughts: Do I keep it or send it back or swap it out? Seems pretty good at 10 on K3 II - will test on K1.
Using for birds and so focus is pretty critical and I shoot wide open when lighting is low…
Will test more but would hate to be without a new lens and expect I risk a worse problem on a swap! (And I am heading out of town tomorrow)
When I bought a 60-250 new it came with needing +10 (or -10, whatever, 10 at least.) I kept it because of my own experience with trying to get properly centered lenses (and reports here on PF of decentered 60-250s.) And it was on sale when I bought it, so I couldn't just re-order at the same price, and keep the best one. Maybe I could have worked something out but it would have been complicated. Anyway I thought Pentax was far more likely to be able to adjust the AF than fix decentering or some other problem. I even did the debug mode thing to preset 5 so I could test for 10, 11, 12, etc. It was a tossup between 10 and 11. Incidentally I had access to another rental 60-250 and it was fine at 0. Well, honestly I mostly tested at 200-250mm and don't remember if it was exactly right at other focal lengths. Subsequently I've found that especially on my K-5 vs. K-5ii AF seems to be somewhat focal-length dependent. Not as bad as on some of my other zooms maybe, but close. Anyway it came back from Pentax (Precision) dead-on at 0 for the longer focal lengths at least. I have other experience with lenses that have been 10 off (2 of them) and one that's more like 12 off, unfortunately. And that's why I dislike Pentax being so stingy with the adjustment range. And if you can send a brand new lens in without a body along with it and have it come back needing 0 on your body, that tells me there's a serious quality control problem with the lens - not just a general tolerance issue.
