06-02-2021, 01:18 AM   #1
SMC Pentax-FA 28-80 - broken power zoom switch
Hi
I have lens with broken power zoom switch, as on photo...
Zoom ring doesn't work, is it expected with all contacts open? Is it issue of switch? If yes, which pads may be connected to make zoom ring works?
br
Andrzej
Redmi 7A  Photo
06-02-2021, 01:34 AM   #2
pschlute's Avatar
QuoteOriginally posted by apaluch Quote
That is a common issue with that series of lenses. Pull the zoom ring towards you and you can then zoom manually.
The best way to get a replacement switch is to buy another lens and swap it over, but I am not sure if the power zoom works on a modern DSLR.
06-02-2021, 03:38 AM   #3
High end models can operate powerzoom like K3 and K1. KP cannot.
06-02-2021, 03:46 AM   #4
Lowell Goudge's Avatar
QuoteOriginally posted by Bertrand3000 Quote
High end models can operate powerzoom K3, K1. KP cannot.
What you say is contradictory, the K1 and K3 clearly are high end models.
For the record, the support for Power Zoom is limited to supplying power to the zoom motor, so you can zoom using the zoom ring, but nothing else, none of the functions such as zoom while shutter is open , image so PZ1 tracking don’t work
---------- Post added 06-02-21 at 06:47 AM ----------
Hi
br
Andrzej
I picked up one for $10 with the same issue. I filled the hole with epoxy, but I can’t recall whether the poser zoom worked or not, on my 28-105 I managed to find all the pieces and put it back in place with crazy glue
06-03-2021, 10:06 AM   #5
That is a common issue with that series of lenses. Pull the zoom ring towards you and you can then zoom manually...
Thank you for advice, worth to know that zoom ring can be pulled but too late - I've just disassembled the lens... and interesting, zoom motor was broken (brushes was exhausted). After bending them to better contact to rotor, motor works (with 5V power supply)... but after assembly power zoom still don't work with K-x. Strange that power zoom is an issue for DSLRs, since it's just matter of delivering current to motor.
06-03-2021, 12:33 PM   #6
pschlute's Avatar
Power zoom was a short lived feature of lenses of this period. Most people, myself included, turned the stupid thing off.
03-28-2022, 10:26 AM   #7
titrisol's Avatar
Location: In the most populated state... state of denial
what was the switch for???? I just one one of these attached to a Pz-20 at a yard sale
03-28-2022, 02:08 PM - 1 Like   #8
pschlute's Avatar
QuoteOriginally posted by titrisol Quote
https://www.pentax-manuals.com/manuals/accessories/fa_lenses_91.pdf
Password is Pentax
04-27-2022, 01:40 PM   #9
Hello everybody,
same Lens here, same Switch Problem, but my copy of the lens shows no problem when its mounted on a Z10. Power Zoom and AF are fine and functional. Mounted on my K1II/K5/K20 im only able to use manul focus and manual zoom and the camera asks for the focal length, only the apeture can be controlled by the camera. Any Ideas how to solve the problem? Would be great if at least AF could be used.
Regards
Chefk0ch
PENTAX K-1 Mark II  Photo
04-28-2022, 05:52 PM   #10
QuoteOriginally posted by Chefk0ch Quote
Hello everybody,
Regards
Chefk0ch
I'd clean the contacts on the lens and on the camera.
I used the very similar PZ 28-105 on my K1/ii for a while as my main lens, and it worked fine as a basic lens.
Autofocus and power zoom were both completely functional. Focal length was also fine.
As mentioned above, none of the fancy features worked, though.
I will note I have a nasty habit of switching the body to manual focus mode then wondering why my lenses don't focus...
-Eric
04-30-2022, 03:14 PM   #11
I made a brief enquiry regarding these Power Zoom lenses on DSLRs a few months ago … conclusion was basically that the feature was only good for flattening batteries on modern cameras
The "trick" is that if you can read the lettering "Power Zoom" then manual zoom won't work, you need to pull the zoom ring towards the camera to engage manual zoom.
In that configuration it works just like any other "A" lens.
05-01-2022, 01:22 PM   #12
Contacts already cleaned a few times, makes no difference, all my other lenses are ok without any problem.
Sometimes the lens is fine, tested today again, got it functional two times: pulled the power zoom ring to manual zoom mode, K1II to MF, switched the Camera on, switched to AF and the lens does what it should. Powered the Camera off, repeated the steps, lens functions again, no card in the camera, so Power off, insert card, Power on, camera asked for focal lenght. Since then, no more AF.
I can really do without power zoom but AF would be great, for MF i´ve got many other lenses. Ok, for AF too, but thats not the point here. I like the colors out of this lens. Example posted in the FA unlimited Lens Club.
issue, k-mount, k1, k3, models, pentax lens, power, slr lens, smc pentax-fa, switch
For Sale - Sold: SMC Pentax FA* 80-200mm F2.8 Power-Zoom sergysergy Sold Items 5 02-15-2020 01:57 PM
FA* 28 70 Power zoom function and switch JohntheThird Troubleshooting and Beginner Help 5 09-14-2014 11:51 AM
For Sale - Sold: Power Zoom 28-80, Tokina 28-70 f/2.8-4.3, Pentax M 200mm f/4.0, New Eyetek Fla hinman Sold Items 23 05-13-2008 07:17 PM
About the SMC FA 28-80 power zoom f/3.5-4.7 hinman Pentax SLR Lens Discussion 22 01-17-2008 05:37 PM
For Sale - Sold: FS: Pentax pz-20, Sigma DL 75-300, SMC FA 28-80 Power zoom hinman Sold Items 9 12-28-2007 03:45 PM
All times are GMT -7. The time now is 04:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
