11-25-2008, 09:45 PM   #1
Pouch or No Pouch?
Okay, here's to all the Limited users. When you pack your gear for an outing, do you pack you Limited lenses in their pouches first before putting them in your bag? I have been doing that but I find it rather cumbersome when comes to lens change. At the same time, I don't what to risk scratching the body of the lenses. What do you guys think?
11-25-2008, 10:02 PM   #2
jsherman999's Avatar
QuoteOriginally posted by leeak Quote
Pouch always, and then sometimes that's wrapped in a large washcloth or small towel. I like to prevent any 'bouncing' in the bag.
11-25-2008, 10:36 PM   #3
Marc Sabatella's Avatar
No pouch. Of course, I don't pack my lenses in the bag like sardines, either - generally they each get a compartment of the (top-load) bag to themselves. The camera sits on top but not doesn't necessarily touch the lenses underneath. But I do drape a folded up handkerchief over each of the lenses at the bottom of the bag, so the lens isn't going to touch anything that isn't soft, but remains easily accessible. Occasionally I'll stack two lenses in one compartment, but if so, there is a handkerchief between them and on top.
11-26-2008, 08:21 PM   #4
Funny you should ask this. I have not used my 31ltd pouch as I've felt it is better to keep the pouch in mint condition in the event that I sell it. However, that theory is going out the window as I truly cannot see myself ever selling this lens!
Answer: Pouch.
11-26-2008, 08:47 PM   #5
vievetrick's Avatar
wish I had a pouch for my 77
11-26-2008, 09:04 PM   #6
m8o
m8o's Avatar
I wish I had a pouch for every one of my lenses. I'm unhappily using zip locks.
11-26-2008, 09:08 PM   #7
For those without pouches, maybe try a lens wrap. I've been using them for years with my large format lenses. They work great. Much quicker to unwrap that a tight pouch, plus they double as a soft work surface out in the field. Cheap too.
11-26-2008, 10:27 PM   #8
QuoteOriginally posted by Matt Miller Quote
Very cool. Thanks for the heads up as I haven't seen these before...
11-26-2008, 11:00 PM   #9
gnaztee's Avatar
I actually have small (but noticeable) scuff marks on my DA 35's focus ring from not using pouch and having it rub another piece of equipment...so, pouches always for me now.
11-26-2008, 11:20 PM   #10
soccerjoe5's Avatar
Pouch for me so far.
Is the Limited lens case available yet? The one where 3 DA limited lenses could fit.
11-26-2008, 11:26 PM   #11
QuoteOriginally posted by gnaztee Quote
The little scuff marks are the most annoying and is exactly what I try to avoid, but unfortunately, those pouches are so darn hard to take lenses in and out of. I go out with the DA16-50 mounted and the FA77 in the bag. Changing lens is such a cumbersome feat. When not using the pouch, has anyone caused any "scuff marks" from the paddling in the camera bags alone?
11-27-2008, 12:03 AM   #12
pouches for the 31, 43, 77, and 35 macro, and I keep them in pouches in my sling bag, as they are too small to occupy a partition of their own. The da zooms are large enough to snugly occupy their own partition, so I feel safe with them in that fashion. I actually bought a spare pouch for the Voigtlander 58, so it now has its own (sad it didn't come with one).
When I am out shooting, and know I am going to be swapping them, I'll take 2 or so out of their pouches and put them in a slot in the sling bag, a lot of the time my wife (aka lens changing assistant) is with me, so she'll deal with the pouches as she hands them to me. It would certainly help her out, however, if in addition to the FA31ltd pouch which is such labeled in gold, if the others were as well, although she's getting better with differentiating between the 43 and 77. Although I might pick up the brown pouch for the 43 (went with the silver edition I think)
In the pocket of my sing bag, I keep spare ziploc bags in case of inclement weather or sand.
The padding in my camera bag (kata sling) is very well padded, and I never got any scuffing or wear from that alone, but the nature of the smaller lenses, lends themselves to that on their own, especially if I put the 77 back in on top of the 43 (they're small to tell if there's already something in there or not) also being small, they dont fit very securely in my partitions, so the roll around a lot, and there is the fear that one day they will simply roll or fly out of the bag when I sling it around and open it.
I lived on Queen Anne for about 11 years, so if I was back up in your area again, I'd definitely keep them pouched. In fact I'd probably get a Seattle Sling if I was still there
http://www.popphoto.com/photonews/5565/camera-armor-launches-the-seattle-sling.html
11-27-2008, 12:38 AM   #13
No pouches, as all my bags are compartmentalized in such a way that there is a padded piece of foam at all sides of every lens and the fit is tight enough without any extra bulk added around the lenses. Should I ever pack them in together without such partitioning, I expect everything will be thrown in some sort of protective casing.
11-27-2008, 12:59 AM   #14
For the last forty years I've been using old socks.
works fine for me. Plenty of padding, tight, compact and easy to get in and out.
And the price is right.
Sig 75-300mm zoom with original case and in sock
11-27-2008, 02:41 AM   #15
QuoteOriginally posted by wildman Quote
Excellent idea Wildman, if only I had thought of that a few weeks ago when I went through my sock draw and threw away the socks with holes. :-(
I use as robust lens cases as I can get. Half of my Takumars have rigid leather cases, and I also use compact camera cases as well. I don't mind the extra space being used up by the extra protection.
Richard
k-mount, lenses, pack, pentax lens, slr lens
Crumpler Pouch LFLee Pentax Camera and Field Accessories 7 06-10-2010 01:39 PM
Hard Case or Soft Pouch? germar Pentax SLR Lens Discussion 12 01-15-2010 11:22 AM
Need lens pouch for M series primes DougLee Pentax SLR Lens Discussion 2 01-11-2010 06:02 PM
Leather flash bag/pouch Sew-Classic Flashes, Lighting, and Studio 2 12-01-2009 05:37 AM
Little pouch/bags for lens vievetrick Pentax Camera and Field Accessories 3 03-11-2007 09:26 AM
All times are GMT -7. The time now is 05:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
