Originally posted by Martowski Well, I ended up finding what looks like a good deal on a new 18-135 for around $250, so I pulled the trigger on that and will replace my defunct 18-135 with a new copy. I was really close to picking up the Sigma 18-200 contemporary instead, but the cost difference didn't seem to outweigh the benefits for a casual walk-around lens. And, I was happy before with my older 18-135.
Thanks!
Wow, that is a great deal! So good, I hope there's no hidden hitch. I've found the DA 18-135mm to be everything Richard is showing it to be. Best of luck, and let us in on your results from it
Even if stopped down just one click, it will often perform very close to DA 16-85mm at least up through 70mm, and centrally beyond that. And if you need the shutter speed, it can keep to f/3.5-4.5 all the way up to 70mm. I also have the DA 20-40mm Ltd f/2.8-4 DC WR, which I mainly use for all-around when going as compact as possible with quality, and the Sigma 17-50mm f/2.8 EX DC HSM mainly for low light/high action use. Other than that, my old DA 18-135mm is certainly the most versatile- and with quality plus WR!!
