Probably not, I have the same issue with the FA*200mm f/4 ED Macro. Most lens collars for third party lenses are removable, I would recommend you get the lens with a collar. I personally find a lens collar an invaluable asset when it comes to stability when used on a tripod, it is also very useful for composition as it allows you to switch between horizontal and vertical framing without changing your cameras height. The lack of a tripod collar was one of the principal reasons I don't own a D-FA100mm f/2.8 WR, and got the Sigma 180mm f/3.5 APO
