06-12-2021, 04:57 AM   #1
Disassembling the DA 12-24mm (esp. front lens)
I recently dropped my DA 12-24mm. It has no external damage but since then, the zoom and focus ring jam strangely (it actually depends on the orientation of the lens and the position of the two rings). I suspect something inside either broke or moved out of its location, and I decided to disassemble the lens (I have a second one hopefully). I coud remove the bayonet ring and the outer body, then I am stuck. I presume the next step would be to remove the front lens in order to access some screws below but I found no way to remove it.
Has anyone successfully disassembled a DA 12-24 f/4, and especially its front element?
01-07-2022, 06:28 PM   #2
I'd like to get below the front element of one of mine, too.
12-24mm, da, da 12-24mm, front, lens
Disassembling front element/group from Pentax-A 1:4 70-210mm huge10 Repairs and Warranty Service 12 03-03-2023 11:25 AM
Lens disassembling: can cemented front element be separated? (K28 3.5, A30-105) Bui Pentax SLR Lens Discussion 3 03-19-2019 07:54 AM
Disassembling Takumar 35mm 3.5 front lens element jns Pentax SLR Lens Discussion 12 01-07-2017 05:13 AM
Pentax 12-24mm vs Sigma 12-24mm & Tamron 10-24mm Comparative Review Adam Pentax SLR Lens Discussion 7 03-23-2012 03:07 PM
A test of 3 ultrawides - DA 12-24mm, Sigma 12-24mm (FF) and Samyang 14mm (FF) DanielT74 Pentax SLR Lens Discussion 14 04-19-2011 11:35 PM
All times are GMT -7. The time now is 06:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
