06-16-2021, 07:17 AM   #1
bdery's Avatar
Experimenting with K&F Concept's ND2-ND400 variable ND filter
Iíve had the chance to play with a variable ND filter from K&F Concept recently. This is my report on it. This being me, it takes the form of a kind of short review 😊
There is a small number of brands for filters which dominate the market, and rightly I take care of what I put in front of my lenses. After being impressed by the companyís system of magnetic filters, I felt quite comfortable testing that one.
The filter ships in a very nice leather case with magnetic closure. Itís better than many other cases Iíve seen, and I actually see myself using that one. In particular thanks to the easy way to pull the filter out : just pull on the piece of fabric (which makes a cradle for the filter). While straightening, it pushes the filter up. Easy and simple.
The filter itself is solidly made. I particularly like the adjustment tab, instead of a pin sticking out, itís a kind of double-sided thumb-rest. Easy to move, less likely to catch on things than a pin, and better looking.
The level of friction is a bit higher than Iíd like, but good enough. There are markings on the side between ND2 and ND400. I would have assumed those dots mark steps where the ND ratio doubles (2-4-16-32 etc) but in that case, the ND400 mark must be interpreted as being beyond the last dot, which would be at ND256. Note that it's somewhat rare for a VND to cover such a broad range while still reaching ND2.
In my tests, I have seen no X pattern regardless of the focal length used (between 20mm and 250mm). I stayed within the boundaries of the scale mentioned above.
The filter creates a subtle yellow tint, thatís not unusual with polarizers (but not something I observed with the companyís magnetic filters). It didn't visibly impact normal shooting.
I used a test chart to see if there was any decrease in resolution. Just like with their magnetic filters, I did not see any observable decrease, thatís pretty impressive! And itís probably the biggest compliment that I can make to that less-known brand.
Below are some test images, just for fun. The results are pretty good!
I will say that the filter is somewhat thick, I much prefer using the ultra-slim magnetic filters, but still Iím glad to have access to a variable ND filter for when thatís needed. I might just try to find a way to attach a magnetic adapter to this VND filter for simplicity.
Hereís the product Iím referring to for anyone interested:
Amazon
For me these results are not really a surprise given my experience with the magnetic filters, and itís an easy recommendation. Cheaper than most alternatives and, it appears, just as good.
06-16-2021, 08:19 AM   #2
I presume the mode of operation is crossed polarizers. A single polarizer gives a one stop reduction in light - i.e. it cuts out one polarization, which is half the light. If the two polarizers are lined up, the second one doesn't affect things much - it just passes the already polarized light on through, so 2x sounds about right as a starting point.
06-16-2021, 08:52 AM   #3
I've done some testing myself using a couple of "generic" polarising filters Ö (easier said than done unless you fix one so's it doesn't rotate!) Ö I found two factors relevant to the "X" effect.
To not have any problems :-
i) - one filter must be a circular polariser and one must be an "old-fashioned" linear polariser
ii) - the circular polariser must be fitted to the lens first
Having only a very limited range of filters to play with, I was only able to check a couple of lenses with all combinations and the above configuration was the only one that was totally reliable.
Inevitably - YMMV
06-16-2021, 09:00 AM   #4
Kozlok's Avatar
Does the adjustment tab work in the little removable door found on most Pentax hoods?
06-16-2021, 11:53 AM   #5
UncleVanya's Avatar
QuoteOriginally posted by Kozlok Quote
If it does Iíd think it would limit the adjustment range a lot.
---------- Post added 06-16-21 at 02:57 PM ----------
Iím hoping that tab can be removed for hood use. But your description of the friction required to be overcome makes me wonder if this can be used effectively without that tab.
06-16-2021, 12:39 PM   #6
Now I know two new words - Janpanese and Putter.
Good price for this type of filter and an interesting design with good promotional features. I would consider giving one a try in order to tame those cases where shutter speed or aperture are not the solutions (and there are such cases).
06-16-2021, 04:13 PM   #7
Paul the Sunman's Avatar
I’m hoping that tab can be removed for hood use.
Agreed!
I see they make several other VND filters: 2-32; 8-132; 8-2000. And a "K&F XB41 77mm Variable ND&CPL Filter 2 in 1 Function Nano Coating No “X” cross".
06-17-2021, 05:31 AM   #8
bdery's Avatar
QuoteOriginally posted by AstroDave Quote
Correct, that amounts to ND2.
Correct also. If the two polarizers are aligned, the second one does nothing more.
QuoteOriginally posted by kypfer Quote
A circular polarizer is, in fact, a linear polarizer coupled with a second component which splits back again the light into two polarizations. So indeed it needs to be the second one otherwise the second polarizer won't do anything.
I doubt it. It's relatively narrow but in most cases I don't think it would work.
I’m hoping that tab can be removed for hood use. But your description of the friction required to be overcome makes me wonder if this can be used effectively without that tab.
It's held by two screws.
QuoteOriginally posted by Bob 256 Quote
Yep, I learn that too :P
Indeed there are many such cases. For videographers of course, but also to fine-tune your aperture and exposure when light conditions vary.
QuoteOriginally posted by Paul the Sunman Quote
Yep that company offers many products. I believe the one I mention is their newest.
adjustment, decrease, filter, filters, k-mount, mark, nd2, nd400, pentax lens, pin, results, slr lens, tab, test, tripod
For Sale - Sold: 58mm Filters: B+W ND1000, B+W CPL, K&F Slim Variable ND2-ND400 sojournaut Sold Items 1 10-07-2018 01:19 PM
Variable ND Filter - Fader ND mark II yusuf Pentax SLR Lens Discussion 2 11-16-2010 11:39 AM
Promaster 72mm ND2 Filter as good as a Hoya HMC ND2? shaolin95 General Talk 1 04-19-2008 03:23 PM
All times are GMT -7. The time now is 05:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
