Originally posted by jatrax
I've had one but the reviews are solid and those that have it report it punches well above its weight. The other option would be the FA 35mm f/2. Available in either the original SMC version or the new HD version. A little faster and a little better made and also FF compatible. You might check around for one of those used. It might be possible to find one for not much more than the DA 35mm.
I would stretch my budget to a used FA if I could. The DA is fine optically and no one normal is going to lose sleep over 1/2 a stop. However, my DA does not focus consistently accurately any more, and others have noticed the same problem with both the DA 35 and 50mm lenses (my DA 50mm has not mis-behaved yet though). I have even gone down the route of dialing in AF adjustments and the inconsistency remains. My HD FA is of much sounder build quality, as would be an older FA model. Used from Japan seem to be the value at present.
If the OP does not mind going fully MF and manual exposure, the K 35mm f3.5 or M 35mm f2.8 are the only options which have a similar price or less than the DA. If the budget is really tight, I would take the risk of getting the DA over these older models and hope that it is a sound copy that lasts over time, as my experience is probably an outlier.
