Originally posted by matroxication The main reason I bought this lens to shoot wide open and everyone were praising this lens for its sharpness across all focal length wide open and I intend to use it for outdoor functions.
Based on the test images from the Pentax Forums detailed review of the D FA* 70-200, I would have to agree with their assessment that best sharpness was attained at mid-range for the lens with very acceptable, but less impressive results at 70mm and 200mm. I would not expect any 70-200ish zoom to be consistently spectacular through its entire range.
Touching back on PDAF performance at 200mm and f/2.8, even under ideal controlled conditions PDAF is fairly imprecise by nature. As a result, even when a lens is perfectly calibrated to the camera for accuracy, a sampling of say 20 focus attempts will show a fair number that are front or back focused. The number of misses will increase with wider aperture (due to DOF) and/or lessened sharpness* to the detector.
If it were me, I would fine tune to the lens wide-open for a focal length at mid-range and let the focal length extremes fall where they may. If you need "tighter" performance, your best option would be to let CR Kennedy do whatever they do to optically adjust the lens and do whatever magic they also apply to the camera.
Good luck.
* Optical softness or subject ambiguity. The PDAF sensor likes abrupt black/white boundaries, preferably vertical.
