07-22-2021, 05:26 AM   #76
bdery's Avatar
I wonder if there was copy issue here because ephotozine tested it on an RP and said there was about 1.6 EVs of vignetting at 24mm and f4. Unless they did the test on jpegs I have no idea what would give such a huge discrepancy. Canon RF 24-105mm f/4-7.1 IS STM Review - Performance | ePHOTOzine
OpticalLimits are generally quite thorough, and have been known to send lenses back when they observed decentering or other problems. It's unlikely they just claimed such results without verifying their results.
Then again, with such huge numbers...
07-22-2021, 05:35 AM   #77
Opticallimits and lenstip looks at actual raw files using dcraw or other software that allows user control. Most other "reviewers" use adobe and are oblivious to forced corrections with that software.
Those using Adobe will report vignetting and distortion as seen after forced base correction and often think the additional correction available is equivalent to ticking the same box for a Pentax lens despite the latter not having any out of the box corrections applied.
07-22-2021, 05:45 AM   #78
UncleVanya's Avatar
QuoteOriginally posted by house Quote
Oddly even the “corrected” output numbers from the two don’t match. Very strange.
07-22-2021, 06:17 AM   #79
But 12 EV of vignetting is not correctable. It just has to be cropped out. Maybe that is true in Lightroom -- you just never see the true corners at 24mm because the software forces the correction.
07-22-2021, 07:09 AM   #80
Thats it. You will never see those corners.
50mm, camera, canon, converters, correction, corrections, data, dcu, dng, firmware, image, k-mount, lens, lenses, mirrorless, mirrorless lenses, pentax lens, primes, profiles, rf, silkypix, slr lens, software, software corrected lenses
Wide-angle lenses which are well corrected for coma Bertrand3000 Pentax SLR Lens Discussion 27 12-01-2020 11:44 PM
CIPA April 2020: trend continues beholder3 Photographic Industry and Professionals 5 06-03-2020 08:39 PM
Nature Mi-Wuk Village - Corrected Shots ginnyfoos Post Your Photos! 2 12-23-2019 09:46 AM
Disturbing trend - giving up all rights to photos! UncleVanya Photographic Industry and Professionals 45 05-21-2019 06:46 PM
Lenses with Pentax Mount that are Fast, Well-Corrected, and Sharp Wide-Open MichaelErlewine Pentax K-1 & K-1 II 17 06-08-2016 05:43 PM
All times are GMT -7. The time now is 05:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
