11-28-2008, 09:08 PM   #1
What to do when 1:1 Macro isn't quite close enough
I already had a Vivitar Series 1 105 F2.5 Macro lens and a Lester Dine ring flash. The lens will focus to 1:1 with no adaptors. If you add the 1.5 crop factor, it actuall focuses to 1:0.666. I recently obtained a Vivitar 2X macro focusing teleconverter (from Fletcherkane on this forum - a great seller!) and was curious to see what that combination would do. This should make the lens a 1:0.333 macro (that is 3X life size on the sensor). The teleconverter is auto as well as the lens, so all metering functions work perfectly. The lens is already huge when at its minimum focusing distance and the teleconverter makes it enormous.
The depth of field is razor thin at that magnification, so I used a tripod for the tests. I took a picture of the seal on the right side of Washington on the dollar bill. I was only able to get part of the balance at that magnification.
I also took a picture of the eagle on the opposite side:
When would I ever use this kind of magnification? Well, the setup is so difficult that I probably would never use this combination in the field, but for at home, when I need extreme magnification this setup works well.
Tom
11-28-2008, 10:20 PM   #2
Actually, the crop factor doesn't change the magnification of a lens.
Also, I believe with the Vivitar teleconverter the magnification ratio is closer to 2.5:1. I did a similar test with my Lester A. Dine 105mm macro when I had the vivitar 2x macro TC and those were my results. I believe the extension is about 25-30mm and this alone, without the 2x aspect, would take the lens to about 1.25:1. Since the extension is in front of the TC part, and since this part multiples the focal length by 2, yet maintains the same minimum focus distance, that takes the setup to about 2.5:1.
Anyway, those are some well done extreme macro shots. The one time I tried the same setup at the same settings, the lighting was bad and the results were bad as well. That ring light would be a nice addition to the kit. I sure wouldn't want to try to do bug macros with that setup, at least on anything moving.
11-28-2008, 10:35 PM   #3
Venturi's Avatar
Is it my eyes, barrel distortion on the lens you took that shot with, or is that lens drooping?
Good crisp shots though.
11-28-2008, 11:05 PM   #4
m8o
m8o's Avatar
Nice; great results. I like that flash adapter.
If you ever decide to step it up, here's one path: https://www.pentaxforums.com/forums/everything-else/13422-macro.html#post110194
11-29-2008, 12:15 AM   #5
QuoteOriginally posted by Venturi Quote
There may be a slight amount of distortion - I was using a Sigma 18-50 zoom at 18mm. The lens does not seem to droop. I actually used the lens pointing down, so it definitely did not droop then. Thanks for the compliment, it was difficult to get the field exactly perpendicular - I ended up using a bubble level and pointing the lens straight down.
11-29-2008, 12:23 AM   #6
LaRee's Avatar
*whew* that is incredibly close Tom! Thanks for the demo.
11-29-2008, 12:43 AM   #7
QuoteOriginally posted by m8o Quote
Wow! I am amazed at the complexity of the camera setup used on the link you sent me. I'll bet the auto metering does not work ;-) It just shows me that the shots I did are not that close relatively.
The flash works really, really good. It has a flash power slider and I just play with the aperture and the flash power slider until the exposure looks correct. I took these pictures at about F22. I wanted to take them at a larger aperture (such as F8 to minimize diffraction) , but even at ISO 100, it would overexpose at the lowest power setting of the flash.
I noticed in your signature that you have an APO Lanthar 125mm F2.5 That is an amazing lens - I wish I had bought one when they were affordable.
11-29-2008, 12:56 AM   #8
QuoteOriginally posted by Votesh Quote
I know that the magnification of the lens does not change, but the distance across the full frame is smaller, so it appears to have more magnification. Something 24mm wide will take up the entire frame at 1:1 on the K20D, but it would need to be 36mm wide to take up the full frame at 1:1 on a 35mm camera.
The ring light really makes macro photography easy. It also has a small non-ring flash that points at about a 45 degree angle directly in front of the lens. I find that I have less problems with reflections using the non-ring part of the flash. There is a switch on the flash unit which makes it easy to switch between the two different flashes.
Tom
11-29-2008, 02:08 AM   #9
Mike.P's Avatar
This was taken with the same macro converter on a Tamron 90mm Macro.
No cropping, using AF360 flash on camera.
11-29-2008, 02:55 AM   #10
Mike Cash's Avatar
A semi-interesting link for anyone photographing U.S. currency:
Be careful not to inadvertently commit a felony
11-29-2008, 07:31 AM   #11
that's some interesting work
how often will you use this rig tho?
11-29-2008, 01:44 PM   #12
QuoteOriginally posted by Mike.P Quote
Wow! - That is close. I'm surprised you could use the on camera flash with that short of a focusing distance. Were you manually focusing and was that picture handheld? How did you get the fly to cooperate?
Tom
11-29-2008, 01:52 PM   #13
QuoteOriginally posted by k100d Quote
I don't think I will use that setup very often. Usually 1:1 magnification is close enough and the additional length and weight caused by adding the adaptor make the setup pretty unwieldy.
I once mounted a 24mm lens in reverse to my Nikon film camera many years ago. It had pretty extreme macro capability and it was a very compact setup. I don't know what the magnification ended up being.
I may get a 52mm Pentax reversing ring and see how close I can get with my Pentax-A 24mm F2.8 lens. One problem with this setup is that the focusing distance is extremely close, so you'd better have a cooperative subject. Another problem is that the lens is not automatic when it is reversed, so you'd better have plenty of light in order to be able to focus.
Tom
11-29-2008, 04:40 PM   #14
Mike.P's Avatar
QuoteOriginally posted by pentaxman Quote
Tom
Yup, manual focus and hand held.
I have no idea why the fly decided to cooperate, he/she actually took off a few times and then returned to the same spot.
Couple more with same setup.
And this one was the Vivitar 100mm f2.8 macro on a set of bellows.
11-29-2008, 05:14 PM   #15
Those are some beautiful shots, Mike.
Tom
combination, field, k-mount, lens, macro, magnification, pentax lens, picture, setup, slr lens, teleconverter, vivitar
Sports 7 against 1: life isn't fair volley Post Your Photos! 4 11-08-2010 01:24 PM
Macro Close up with an 105 Macro arbib Post Your Photos! 5 03-19-2010 06:59 PM
Close Up filter any GOOD for macro? Adrian Owerko Pentax Camera and Field Accessories 7 12-30-2008 10:25 AM
Macro or Close-up metalfab Post Your Photos! 5 03-21-2008 06:50 PM
super close macro trev99 Pentax DSLR Discussion 23 02-01-2007 02:28 PM
All times are GMT -7. The time now is 04:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
