Originally posted by pschlute Setting it to AF CANCEL means the 4 buttons when pressed will turn off the active AF. Far from inoperative.
mmmmm. ok.
Got to admit, no idea of that.
when i first used the lens, i had this same problem, that being, i found those 4 buttons to be rather irritating.
Then i fiddled around and found setting it to AF Cancel to suit what i want to do.
And for the 2years plus using this lens, this solution (if i could call it that, even if it is a half baked one) worked fine and will probably work fine for the next 2x10 years.
If anyone else has the proper way of rendering those "irritating buttons" inoperative, please do share with the OP, as my suggested solution may not be suited to OP.
