Originally posted by Fogel70 I believe that is a later version of Sigmas TC that has never been available in Pentax K-mount. The Sigma APO EX DG 1.4x TC is older than that. Probably from early 2000s when many of the Sigmas EX APO DG lenses came.
Ah, OK.I know there were earlier versions of this one before the 'DG' version (which means 'optimised for digital' as I understand it) but yes, perhaps it's a bit older than I thought :-)
---------- Post added 07-31-21 at 07:56 PM ----------
Originally posted by kypfer You're correct, the camera will under-compensate, which has got to be better than the other way around … 1/30 @ 420mm is good going, what ISO were you getting? Probably plenty of room for adjustment!
I use the Sigma EX 2x with my Sigma EX 70-200mm f/2.8 quite regularly (and Kenko a/f t/c's with other lenses) and none of them notify the camera of their existence. I simply let the camera do the best it can with the information supplied and am rarely disappointed
Admittedly, I've usually got the shutter speed fairly wound up to compensate for (wildlife) subject movement, so the in-camera Shake Reduction probably doesn't have a great say in the matter … given the low-light capabilities of the modern Pentax cameras it's rarely an issue for me
Hah, yes, I wouldn't rely on 1/30 at 420mm normally, esp. with the K3 iii's high ISO performance - I was just experimenting with SR :-) I tried a bunch more test shots just now handheld and standing up at 1/30 / 420mm and the results are certainly variable even with SR. My best shot with SR was totally sharp, but my worst one certainly wasn't, even with SR enabled. My best shot without SR was surprisingly good too, but still only as good as the worst of the SR shots. So SR definitely helps, but good technique and a steady hand are clearly still important!
On your other question, no, the TC doesn't correct the aperture either, so the camera still thinks it's F4 wide open - but I don't think that really matters in practice.
Thanks all for your replies and sorry to dig up a question that's probably come up plenty of times in the past...
