I must say I'm a more than a little shocked that the Zeiss lens dissapoints. Then again, I've never seen one, let alone your individual copy. How do your lenses look if you shine a light thru them and check for haze/fungus?
DFA* 50 1.4 is better than decent. It is in the top of its class, which is a very competetive and refined class indeed. I don't think it's your location that makes it hard to find a better 50mm for Pentax than that lens. There is no better 50mm for Pentax.
Can I ask what specifically was dissapointing about the results with your current lenses? Did you try your tests with DFA 24-70 zoomed to 50, and how did it compare to the legacy primes?
I won't belabor it and I'm not doubting you in any way. But are you doing everything to be sure you've eliminated shake, exposed properly, and focused properly? And did you review all the settings on your camera?
Sometimes when I get surprisingly bad results (with anything, not just photography), I benefit from starting at the beginning and going over all the basics. I've been known to make a rookie mistake on the fundamentals, even on tasks that should be automatic for me. And I've seen the same thing in others who should know better still than me.
Alternatively, if you are just looking for help convincing yourself to buy something new, I say this:
Go for it! DFA* 50 1.4 is a terrific lens for your terrific camera. You are clearly a discerning individual who expects impressive results, and I think a good copy of that lens will be right up your alley.
I love mine, despite it being far wider than any of my other favorite lenses.
