Originally posted by richard0170
Oh no they don't!
Due to the complex lens designs needed for WA lenses on SLRs the image quality can never be as good as those designed for mirrorless systems. There are no optics in most adaptors so no compensation going on at all. Add optics and there will be a further degradation of images.
Richard, I'm quoting you. You said flange distance.
The adaptor makes up the difference in the flange distance, there is absolutely no problem in using a DSLR lens on a mirrorless.
I shoot both Pentax and Sony, so I know!
So, with reduced IQ inherent in the SLR WA lens design and the extra bulk required, why would you choose to use them on a miirorless system? Maybe due to cost I suppose, but many of the best WA SLR lenses are not cheap.
On the issue of mirrorless lens designs - that was not the topic, Richard, the topic was DSLR lens designs - they have advantages and disadvantages because of their short flange distance.
In theory you can do without the retrofocal group, but in practice, you put it in anyway. You want the rays to come back gun barrel straight. A high quality MILC lens looks very much like a high quality DSLR lens, and weighs and costs as much.
And wide angles so close to the sensor are problematic.
The bent light from the edges is extreme. Enough to trigger a grain of film, but perhaps not a digital sensor. That's why makers like Leica and Sony at times have had to add a distracting, image affecting microlens array in front of the sensor to try and capture more of the light and lessen the vignetting. This in turn leads to artefacts like purple colouring. Pinholecam actually paid to have his microlens array taken off his Sony A7.
