Originally posted by 8540tomg Might I suggest the K 300mm f4.
Thanks a lot for the tip and the link to the other thread!
I'll go and do some reading.
Originally posted by Lowell Goudge I put a link directly to some shots I took with the 300 F4 and 1.7x AF TC (making it a semi autofocus 510mm F6.7.
Thanks much, I'll check them.
Originally posted by philbaum I bought a Tamron 1.4TC to go with the 18-250, but later on, i found out that Tamron doesn't recommend their own 1.4 with their own 18-250.
Will AF still work? Without putting on a high strain on the camera motor?
Originally posted by philbaum Also the 1 stop of light loss due to the 1.4 makes a difference indoors as well as evening outdoors.
And outdoors? I guess with "only" 1.4 magnification the IQ should still be OK, given sufficient light?
Originally posted by hinman Hinman, these images are awesome!
Not only do they demonstrate the sharpness of the lens, they are also really great shots. Chapeaux.
Originally posted by Arpe You realise that's there's not much diff between 250 and 300?
Hmmh, I theorised there wouldn't be much difference but I wasn't sure. The last 50mm on the 18-250 do not seem to make much of a difference. Extrapolating that, you're right, 300mm cannot be a world of a difference. But then the 18-250mm gets slow at 250mm and some say even "soft". I think one can still take decent pictures at 250mm but let's say a prime at 300mm should be faster and sharper and that's a useful difference even if the reach isn't terribly higher. It would allow for cropping with better results and this way give more reach nevertheless.
Originally posted by Arpe What are you doing this Sunday avo? I'll probably be at Elsdon Park photoing.
It'll be great to meet you there. I'll check my availability and will contact you.
Originally posted by sharko You shouldn't use a TC of any sort with the 18-250 superzoom as it will not autofocus at all and the viewfinder becomes so dark its hard to see anything because of the loss of light.
Not even a 1.4 x TC?
Originally posted by audiobomber But due to its design, the 18-250 doesn't have reach like a true 250mm lens.
Depends on where you are focusing at. The IF mechanism changes the effective focal length depending on the focus. In his
Tamron 18-250mm F/3.5-6.3 AF Di-II LD Aspherical (IF) Macro Review Bob Atkins reckons that the effective focal length of the 18-250mm is ~125mm at its close focus distance of 45cm. But focused at infinity the focal length should be 250mm.
Originally posted by audiobomber At about a mile, the 18-250 looked like 230 mm.
Interesting. I guess a mile should be practically infinity already, right? Not sure whether focusing any further away would help but it seems odd that Tamron would specify 230mm as 250mm.
