12-16-2008, 06:57 PM   #31
FotoPete's Avatar
oh geez that was a close call viz. Good to hear you made it out in one piece!
Ah I have a similar setup...minus the 400mm. Too tedious to remove the adapters the standard way so I removed the retaining clip off my pentax adapter and drilled holes on my Jupiter-9 and CZJ135.
My 3rd party one is tighter than the pentax one so I use that for my takumar and turn it about half way until the resistance from the clip is high enough that the lens won't unmount, but the clip won't lock either. (I'm lazy haha)
12-16-2008, 07:29 PM   #32
Just converted my jupiter9
12-17-2008, 05:47 AM   #33
vizjerei's Avatar
I tried to unscrew the adapter off the lens but no luck, that's also why I convert the lens itself.
Anyways here are some photos I took with the 400mm, except the first photo of course
https://www.pentaxforums.com/forums/post-your-photos/43983-icey-waterfall-some-bird-prey.html
400mm, flash, hole, k-mount, k10d, lens, m42, pentax lens, pin, secure, slr lens, spot, tripod
Long telephoto lens support nicolas1970i Pentax Camera and Field Accessories 16 10-01-2010 10:21 AM
HowTo long range telephoto shots falconeye Photographic Technique 3 04-08-2010 04:32 AM
Suggestions on where to get long M42 mount lens cleaned theedudenator Pentax SLR Lens Discussion 3 05-18-2009 04:35 PM
Cheap, long-range telephoto lenses any good (how about prime ones)? bjsmith Pentax SLR Lens Discussion 35 06-21-2007 10:53 AM
All times are GMT -7. The time now is 06:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
